297whp Wolf 3d EMS Dyno *vids
Pistons are IN! (CP 8.5:1)
No more stock pistons
avarela86 said:
Nice...Can't waite to see the results. Still on the MAM rods?
Yeah...MAM (K1-Eagle type) rods.
Just a quick note. I know a friend who has the same rods, used for years and boosting over 30psi, over 500whp on a 3/4 chasis Toyota 22R.
He blew 1 rod when he overboosted to 55psi!!!!!!!!!
Ill try to take a pic
^^^OK im sold...Why go through the hassle and spend more in Pauter(in my case). I'm not even planning to go past 270 WHP.
Shadup and post to ther forum i told you. ;-)
I didn't check the vids due to crappy internet, but what was the trq on the 297hp run?
Also what does your IC look like? i mean you gave the dimensions, but from what i'm reading your causing a small bottleneck in the system. I had a simliar size core on my other turbo car and just changing the IC gave me 2 whp and 33 wtrq more with LESS boost. was running 26 psi now on 24 psi. So i defintely look into it.
Nice numbers but can you post trq numbers also. Remember Hp is nice and important, but TRQ moves the car.
Might need to check that...i sold my computer and backed up the info on an offline disk. All info available is here.
Good question. Pauters have been nothing but reliable.
