Disable Engine Harmonics Enhancer (EHE), Fake Engine Noise?
Anyone figure this out on a 2024 CX-5 Turbo w/ Bose?
I just added a sub with a t-harness at the factory amp, and now I’m hearing the fake engine noisethrough the sub. I’ve seen it called engine harmonics, active sound, or ANC, but I can’t find a confirmed way to disable it on the Bose setup.
Any fix or bypass?
Isn't that great! AFAIK there's no solution. The Ford fake sound software switch is in the asbuilt, in Mazda hasn't been discovered yet. I would bet is located in the Instrument cluster asbuilt.
This block diagram is from a Mazda3 turbo, for CX-5 replace in drawing the BCM module with IC.
Dumb question since I just got my CX-5. Does everyone with EHE and an aftermarket sub just deal with it?
I have the service manual but not sure how to dig deeper into this. I can post any diagrams needed from it, if you or anyone has some ideas.
