R RuZec Member : 09 Mazdaspeed 3 Jun 8, 2010 #1 I dont know too much about the whole rim and tire deal but will the 2009 ralliart rim fit on my car? Will it be too big or too small?
S shaneS Member : Speed3 CWP Jun 9, 2010 #2 They will fit, I dont know the exact specs, but I know the EVO X BBS are 18x8.5 +38... it may be the same. Itll take some fender work though
S spdjnke Member : 08.5 CWP Speed3 GT (sold) Jun 9, 2010 #3 Roll the fenders and you should be just fine.
G GoFast Member Contributor : 2010 Flyin' Carpet Jun 9, 2010 #4 you may want to check the hub bore on those wheels...our hub bore is 67.1mm so any rims have to be equal to that or greater Last edited: Jun 9, 2010
CTt3P5 TAD Moderator Contributor : 2016 GT ST 47A Jun 9, 2010 #5 ^^^They don't have to be greater but if they are smaller you better trust whoever bores them out to 67.1 VERY well. I'll also add that if the wheels have a lareger hub bore than you can purchase hub centric rings and all will be good.
I iheartmyhatchie Member Jun 19, 2010 #7 They are 18x7 +46 with a 67.1 hub bore I believe. They will fit just fine.
