2003.5 Custom Fog Light Kit
Status
Not open for further replies.
Can you type bigger? I got a hard time seeing!!:)
Oh! Never mind! I just remembered i'm trying to look at small fonts on a 1280! My mistake!!!(spin) (drunk)
Newf said:
Dr.Sound, which ones you going with?
sup newf,
i just ordered the brackets alone.
my thinking is that if i go to local Autozone and buy fogs there i'll have worranty in case anything happens.........i will also be able to return the fogs if i dont like the style.
oh and Brian, thanks man.......and thanx for all the work u've put into this.
Dr.Sound said:
sup newf,
I received the tracking number. I will track it tonight but will have it tomorrow. Honestly, this gives me the weekend to get everything in order. I have like 15 orders to fulfill - thanks everyone! I'll ship everything on Monday.
- Brian
I'm in no rush for my back-up set. Ship mine last if you get behind the 8 ball! Will these drop in ok if I have to remove the Gen-2's? I got my harness extension wires soldered in. I'll try and get em' lit up by Tuesday. Can't wait! I'd do it this weekend but I'm goin skiing in NY all weekend.
367 (mp3yellow
367 (mp3yellow
Me behind the 8 ball - how dare you! (just kidding)
They should drop in okay - remember, you will need to bend/paint them first (simple to do).
Good luck!
Good for you Brian!!!! :) Thanks for keeping us all updated on the situation btw. I will gladly post or send more pics of the new plates installed, even with my broken lens. (sick)
Good luck!
The G3s don't come painted black? If not what what was the paint that you used or were you doing blue too I don't remember. hit me up!
Quoted earlier: Rustoleum flat black, 5 coats + clear coat, 3 coats. This should last quite some time. Repainting it should take an hour after a period of time. Treat it the same as you would repainting your bumper.
I this it?
I this it?
On the G I and G II - I had done this (when there was a lot of manual labor). To bring the price down from $60.00 to $50.00, I had withdrawn the painting and with the new redesign there is no adding additional brackets, screws, and grinding...
www.03msp.com/products.htm
G3 BRACKET Specifications: Laser Cut, 14 Gauge, Mild Steel, Eight Self-Tapping Screws, Unpainted, and Patent Pending
I would recommend Rustoleum brand of products - flat black or the new epoxy product (very nice). About $4.00/can.
Also, for those of you whom will receive the brackets - you will need to bend the tabs out (like holding your arms out) and depending on the lights you choose, you will may have to bend each tab slightly to accomodate your choice of lights. (Kev, II, Cat are excluded from this statement).
- Brian
Guys help him out... He worked hard on it.... I monitored the fourm just like u guys do. And besides fogs make ur MSP different from everyone else's.
EXACTLY - DIFFERENT FROM EVERYONE ELSE!
Thanks everyone - keep on truckin' (yeee haw).
(cheers)
Everyone,
a) For those of you whom ordered just the brackets, each set has been placed in a padded envelope with 8 screws and labeled with your address's to ship on Monday.
b) ^Tyrant^ - your brackets have been test fitted to the 362W's and have been bent and 1st stage of painting. I will finish the 2nd stage of painting tomorrow and ship on Monday.
c) Kevducrider and II-Savy - your brackets have been test fitted and have been paint and 1st stage of painting. I will finish the 2nd stage of painting tomorrow and ship on Monday.
d) CatD399 - you have a PM.
- Brian
Status
