howdy all, new to this forum, not sure if im posting in the right spot.
mid february 2012 i replaced my 96 subaru outback with a 2002 protege5. it has 216k on it, (thats 135000 miles if yer from south o' the border). its only the second car ive driven recently with a manual transmission. the other was a buddies 03 impreza. (drive a single axle dump truck fairly regularly just u cant really compare the vehicles.)
Right away i love the car. the guy who owned it before me, owned since new, was completely anal about the maintenance. he gave me a cd that has the shop manual, parts manual and his own spreadsheet documenting every single little thing he did to the car. even changing from winter to summer tires he has it listed with the mileage and also the cost to have the work done. the guy spent over 7 grand on this car since buying it. ANYWAY, right away i noticed something with the transmission. when shifting from second to third, it seems to catch a bit and grind before mating. not like if you shift without clutching, just a bit of a snag. i came online and started snoopin around to see if other people had this prob. what i found was people saying if your motor mounts are worn it could cause probs, and if they are fine, switch to synchromesh tranny fluid.
checked my mounts and they are mint, so last week i changed my fluid to pennzoil synchromesh. did not find as much of an improvement as i would have preferred. it doesnt catch as much shifting into third, but now i notice its doing it from first to second. my mechanic is telling me the syncro ring(s) likely worn, just double clutch. i dont drive the car everyday, i drive my truck, my gf uses the car daily to and from work. every chance i get i play with shifting at different speeds/rpms, holding the engine speed while shifting, double clutching etc, but i really dont think these things should be happening. comparing it to my buddies impreza, or i guess any working 5spd tranny, the shifts are way smoother in his car than mine.
i guess my questions are if anybody has had similar things happen what have you done about them. i have no reservations about replacing my tranny if i need to when i can afford it. is it as simple as taking another tranny and tossing it in, or do you have to repack the gears etc (never done tranny before, not scared to try.) i trust my mechanic when he says the syncro rings (gears?rings? cant remember) are worn or wearing, considering brass is fairly soft, he says its gonna be around 2500 bucks if he has to redo the tranny, which i think is a bit steep but it always changes when he actually does the work for me.
any info anybody has, advice etc i would greatly appreciate. i love the car so far, cant wait to see what its really like when it runs properly. thanks in advance.
