2002 Mazda Protege Lift Kit
Boulder, CO
Rally Protege
Hi all,
I made a lift kit for my 2002 offroad Protege and thought I'd share the process here. I found a few people who managed to gain an inch or 2 through larger tires but didn’t end up finding anything about lift kits. I figured the most that I could lift it without upsetting axle angles too much would be about 2”. I probably could’ve gone 3” in the rear but better safe than sorry. I started taking a few measurements to draw up a template of the tophat mounting plate. After taking a few I realized it would just be way easier to buy a strut mount and take the measurements from that.
bMLdq7WDN6CYgKGhzsMWJl8i9bxED2svn25an0chqOhj8zOF5Kq0hnfZRkOYoQIKcm4bBGH_a_wNfhsKNByKpbfPaHNrMFkcEM96U0J1QgbOTGxgNaJV8lLJwShbUejxoTemnhQHHLR8hR5kAjQn89CtOr4cBVsfiWGGk01-wAIjtx-n4pCnbgwY15iCHw
This was the front template once I had the bolt holes drilled and the design drawn out. I wanted the lift kit to be the last thing on this car to break, so I used ¼” cold rolled steel plating for rigidity and strength.
5fKRYzp5vRxaxdS9Aifat8_tbjmk_Bmw-cpnGfOSPyVXSRpqf20VI08HuaFIxlk_S-ltDrJndlaHsxXwvvITm8WCnmGG9Sno_Gp1rzFZ2pUW-mqTNyVzSobRE_-hj_z8Suzy__9OgzizkRYhnN2eTNsLEBtINGuCwnI4eyT9CSDXhjhGAgTEOZ_caMI9tw
This is the template with the strut mount test fitted.
RuW1Nh33pCEYxlhU9-krIkL_fmolJytE3QpLy0eCLSIgHDy7l2SYcZSqEhx_swIKdo8SdxWjG2GoTx-Jnasmb23FspEEvp8KfP3moymC1t3HFZEJub6jUy34k2bEF6FG-1lHjLc5NMNNcsL2cRwW36EVxkGc2H6FToJQWfDSwK0RhBgfsK1JAUsXVkQ70Q
bTA-hO2dw9y_cTC9K_H2OlWXKD6X1_YtAOItsVrB3h3S_IkHfZXRqpO7JdJdC_uKQDtAaHCtug7dpPdNylAPLyRg6Y-dH1Dhuqgt9rKnj2KuEXTUyIqoaheDZPGAMA5UyTRktTzenDTYVAfNQINICIafjTSN-mvqKp9nYwg3wAWpF29y0A5g84gDEqIwng
This was the front and rear template after the centers had been drilled along with the bolt holes.
1LM7c9gSLNl0pgqM0yXFlN2cbeRiST2gOT3LLHK7--pzwk1Iht-GkKzE7YiNdgot66O_s8aV4eXe5qBAK830mgkAoZe2rttGf4xvd2Q3AAQH3OATEGyqU61mf3J8g36OjgFwTgZj-OhvGo9Gi2LqaegEYK6dxdi3P8bIdAEkTiMwdkhgzoM_KYZFU2ThmA
RJjLgqFgQZJN0dKgFQADoV5p4CvvlJfp6CVxSl2U-Z-Tup8nRLZtgk12CYMuJL6DHfFuIVJofsQVq4V1eWt38MKtgWXWp5p9cW75saVM_RgNjQSGj96H9qT1cp7oVoZHEtKNlcB7jpDU02E4z7-yCS4sYHUD_QKWjHtyWFs0E-ZvBHNApNO-zbZoGARFbg
I wanted to be consistent with materials so I opted to use 3” diameter, ¼ inch thick cold rolled steel tubing. I cut the tubing into 1.5” sections, so that when welded to the ¼ inch plates, the lift would total 2”.
LfczkUAkqqHMGsfJXtNq1KGUG8eWg7OBA2eFmsmEoTt_YC_j_AjgqCjICWo-Y8ZSTF0xGsi-ghK6pjM9gxjeaIy2tM-Dq-CUh6g1SJAzDNUNi_SThVmEKfJdTTtZrhd-gR5UlT1cpfltYPmmWI0wrI0MHztH0yThrt0rKGVhvTSPwjsLYql4kGzMMvwLkg
dwU4OFXO_2DPjY-pkCBk5sAiQZecKA18H65AhS2J1J0QHnR93KMrrwXsQHIA_6WpW2Ky3MpD1Jg6AVOvookKhdi0TYCxgrQ1o-51vk96fMEAT2xZ5Iy0LbOIRKeVcfpolIgJNDXTfKnuWO8DFv_Y7h-fXFvgPAeym50nbPBZnRs872dQFxoVoNmivKPtXg
LCiTExXvBOncXtWE6RVEw4dHtVnfL8W-4fgSQ2PV3VknyvMWPBn_H3n-d85kw_2Hoc9PhFUlGFzINNbRVEjb8zjb6p1o43HMYPy7KdMpTx3d1NMkHzZtdT7xDZssO4QwoFfRdixilHsWiyBANyyB_-aDL_jKwjQ-Wg_gBNgYwtr7FFlVfmN-Bg03jUeJpA
Once that was said and done it was time to tack everything up. I cleaned up the edges of the templates with an angle grinder and smoothed everything up with a file. I tacked the first one together and lo and behold, this was looking like it was gonna work. Everything fit perfectly when test fitting so after that I decided to weld everything up with a double-fillet weld for strength.
HaOYCBhnlstMGzWnhMhb8BopqUot4jlhjq0cu6GS9K-PVCMeP4sHU0pURL37nSWXXcgrqFJn51oRxJ1J_7Snm8KUrzk_zrunVf0bbqB7ZkYKLzVdMcM6Okq4fZIF2rx2udiou7l-XlhCV2g_WITVJLh0OKmIbqb7UIGs7B-9X5O3eAjLT4yba2WQKMnRlw
wZpLWKmQOOPUG5RV2uW3sydkwiiTh2_fbJJSNRjZaKXCQx56dF2n9Y0IhPaPtFF18KUqHqEXObBUv7JmSvgHnsDbNH0Wnn796lcJyugHF-0esfB7Z0PVTa8QjBaEme2_Ehffsx1RQpWB3H9IKha1PVyBN-cqh2VjcO0eJzcimnEHC9cJxZ4zEqNt92fdaw
I welded some Grade 10.9 M10 hardware in for the lift kit to attach to the frame and gave it a good coat of black paint. I used Grade 10.9 hardware for the bottom bolts as well and tightened everything to spec. Everything happened to fit perfectly. There were no fitment issues and everything bolted up like oem.
YFlszITZB_vpKYrMgJctek6IlKgm7sMd88xGLZBJgVkG_7udXyU4YX1zsSGM0E4GsRX_V8lcdZf-eNZWrs6gs7P9accvyx7F1Jdz_xnaeuOikXVCQ5J5sMXpD7SUYHxwABhphl0N7Zdk32ch6WhS0QvbXiUu0HXs5TokO4YHowZH0oQ15_J6xSp9fCuyzg
BXxQN4aesNiQK5rFcgZ28ovdUg8gR1IIgWaw92CsSnYAaIZsgvjbcuZ3mt6A2Sga1sbpUQk8Brhe7VZxLLgeaehtpmOliVSJ12vjviGpPwzKQnjG-oKbszy1FNgfwnVasxHuuD-0aC0e2pkIjxZoyIWKWef3t7yO4DAxGRM4xBLmwAEHRYZoeWx_3PjbzA
0q_rTLbJeHWmm_-FMGThY3wPeH0p8phr7h2O_E2Pts2HMPIWEGu-1hefTKR8eJpOP0O3rT3JsuUp1rZKmLNqkQnnetP_KapA1HyIM4c48ZNUY6ry_d_1zuwnIzrybJlXzz2yQ-dsPpzlQ5IPfVspC7sM7biVO5ZdbJOhxtZFIFielKP-UhHXdctnqaJXrg
The thing looked absolutely ridiculous lifted with 185/70/r14 and so naturally it was time for bigger wheels and tires. This was how the car sat right after lifting it. The second photo is with 2" spacers and 29" tires.
ApbqB1U6DP8hXe0aYbR08eAomLeyHUhmGN00ZrSirLypuXGEiBdtS-wFiZEDfg5phY3s7bZhJtwMdXhyMaUTQkTBqSO-Wroac15BviCwjI4_0nfZB_obeA7lDgvKDr82WDdYzC-8aa05jDl-pZsPkPhubjP1KvKoIhEnpRTnws03SUQ5v2oFFIOeeRtOOA
ed8Zpa3ShjoEnyTA3Vkh1LNZduq9Jya097OhJ7PdOJMicUi3KAwQuMfuaYPs4b6PftYeUiV6f0gaFRFIbo3PoEIuCqB6MvXwkruYjPbJSx6WQWn7sOx46rkNwev9vLXu9nBGLRudpZgLLZnDXYvzjSKfvI96Dmeegsd3b6iqg_P9TQTVG8rd3oM8p4AloQ
Wow. That last pic looks absolutely nuts! I probably won't ever do this to my Protege5 but It's certainly cool to see, and makes me want a second lifted Protege as a rally/beater.
Thank you very much! I've put a ton of work into it and probably have a write-up coming soon, the thing is a blast offroad!
Awesome project, thanks for sharing it with us! A write-up would be great, also updates on future mods, performance and repairs etc…(y)
