ps. Plug wires, not the plugs themselves.![]()
Plug wires is an inexpensive fix. I would try that and see if it helps.
Hey guys, here comes another!
Now, this car has had some work in the past. I actually just grabbed the paperwork:
June 2005 - 87,5xx the car was overheating. Thermostat and Head gasket changed, resurfaced head. EGR valve was cleaned out.
September 2007 - 115,177 car had P0420, P0171 codes. Catalytic converter was replaced. Also found a crack in air intake boot. That was replaced as well. Air induction system was cleaned including throttle body, air intake, fuel injectors and intake valves (I'm getting this stuff right off the receipt)
AND I just realized this is in the 2.0 section. Ooops. Maybe it doesn't matter? Lol
18 dollar coil pack? Where?
808MP5... which coil packs did you get from rockauto? Standard Motor Products or Airtex? Not that it makes any difference... I'm just curious. I'm also assuming they are sold individually so you have to order 2?
So does anyone know why the AC Delco coil for the 1.8L is 1/3 to 1/4 the price of the others? That's tempting to order for the conversion but scary since it is so cheap compared to the others.Either is fine. Be sure to chose the one that doesn't say any kind of business day delay beyond 3 days. That means that it is out of stock.
Use this code: 14406931116418 to get 5% off. It expires 04/12/2009.
You will need two of them.
i have a 2001 automatic mazda protege i love my car to death never really had a problem with it until now. i called the dealership to ask them what they thought the problem was they wouldnt answer. so im here now asking for help from you all im a girl and i have no clue what i need to do. my check engine light came on sat and i changed the air filter sun evening in my car the check engine light went off now its back on again. i took my car to advance and they said it was a misfire issue with the ignition that it could be sparks and coil pack and wires that need to be replaced is this correct you think? how many coil packs does a mazda protege take? please help i dont wanna pay a arm and a leg just to fix this car thanks in advance for the advice.
