Now, I'm going to go contra to my own views in one small way -- Darth is right that the Forge, when adjusted properly, will recover quicker and let you come up quicker on boost in the lower gears.
It is more "lively." But it also can be abrupt and can cause drivability issues if not carefully adjusted and maintained. Like so manyt things in life, it's a trade off of competing values.
I prefer the stock BPV because I think I have about all the lively I can handle in gears 1 and 2, being able to break them loose at will. It seems to hold boost as well as, if not better than, the Forge under higher load conditions, while operating very, very smoothly, even if a bit "doggy" in coming up on boost in the lower gears.
So, either the stock or the Forge make good choices, but for different reasons, depending on your priorities. Try it both ways and see which you perfer. But don't junk the stock valve under the mistaken belief that they are all POS leakers. They are not.
