10,000 miles
Kyrosfactor
Contributor
MazdaSpeed3
I just got to ten thousand miles on my 2009 MS3. What are some upkeep things I should have done? Thanks in advance!
10,000 miles should be fine..just check your fluids..but they should be ok..obviously change your oil every 3-5000 miles..everyone is alittle different..tire pressure should be check weekly..least monthly..rotating your tires wouldnt hurt right now..but pretty much your in the clear..10,000 miles your car has barely broken in..when you get to around 20k..maybe look at your plugs...instead of worrying about what I should do every 10k or 20k..I just do daily checks on my car..pop the hood now and then and check my fluids..i tend to change my oil every 4000 miles with full synthetic...If I feel my brakes starting to fade or "sqeak" then maybe its time to change the pads...anyways thats my 2 cents.
All good advice. Hopefully, the car is on its third oil change or so. Tire rotation should be coming up for the second time. Air filter clean or replace, depending on conditions.
