Laser Blue Protege5 Build
Looks to me like one of all the other 4-1 short tube headers that are available for the car. Back in the day, the one tog et was either the 4-2-1 AWR header, or the 4-1 long tube RActive header. There was also a long tube 4-2-1 JDM header, but that one required some re-work to the mid cat pipe to make it fit.
You could also make the 626 / MX6 / Probe 4-2-1 long tube header fit with some re-work to the EGR bung location. It might have needed some re-work to the mid cat pipe, too.
Now I am looking for a cat back exhaust since I am still running stock behind my gutted second cat. Any recommendations?
How much do you want to spend? Also, there aren't too many product still available for this chassis.
Racing Beat makes a great product, and will give reasonable sound behind a cat-less header. But, the cost is quite a bit higher than some of the cheap "EBay" style products. Megan Racing makes a fart-cannon style exhaust for (relatively) pretty cheap. The Megan exhaust is probably going to be pretty loud, too.
Full cat-less... I would probably recommend Racing Beat. It will keep it relatively quiet, and still have decent sound.
@njaremka I looked at Racing Beat. Not too bad, but definitely wish there were more choices. I do not want the fart can sound for sure. I may have to go the Racing Beat route. Thanks!
Magnaflow made a great exhaust back in the day, and that's the one I ran on my Protege sedan. A little less expensive than the Racing Beat, and had a great subdued sound. Unfortunately, not made anymore.
This is the headers before install.
I'm fixin to do another thing. Found these on Amazon and I think they will work. The top one clears the inside of the fender with just a little light tapping on the metal and the bottom one will screw right in after I drill and tap the existing fender bolt hole. I will get gas struts extending out to 20" and retracting to about 14.5. I just have to figure out how strong they need to be then goodbye prop rod.
Links for the ball studs:
CAI was a little wobbly at the filter end so I fab'd up a little bracket. Cleaned and painted the overflow bottle bracket and used it to mount the support.
Got the struts in. They lift the hood easily and put it just before the hood stops it upward motion. Slight clearance issue when I close the hood, pushing the back edges up slightly. I will either live with it or clearance the fender metal below. Haven't decided yet.
These are the struts I got:
Nice work and looks great.
The only reason why I hate them is when needing to get to the engine compartment from the sides of the car.
Dang struts get in the way. 😂
I did another thing.....
Not just any 2005 Mazda6 V6 5-speed though........
An S Wagon! Or would that be a Swagon?
Just rolled off the auto transport from Stockton, CA (can actually see him rolling away in the background).
Paint is a bit rough on the horizontal surfaces, but there is a Plastidip sprayer on the way as well. Rest of car will take some work too, but it does run and nothing majorly bad sounding coming from the engine bay. Now I have 2 money pits to work on.
Nice! My favorite Mazda6 model (even more than the Mazdaspeed6)
The DYC sprayer is here now too. Will be a while before it gets used, but plan on both the P5 and the 6 Swagon to get shot with it.
Just rolled off the auto transport from Stockton, CA (can actually see him rolling away in rhe background).
Would make for a great project thread in our Mazda6 Forum...😁
Got lucky that the Tucson Pull N Save got in a wrecked P5 about 2 weeks ago and it had the full roof rack on it. Just went this morning and got it. 50% off first Sat of the month and it got me the whole setup for $30. Quite a good day if I say so. The driver side plastic is all in one piece, but the plastic on the passenger side was sun weakened and came apart a bit. I will see if I can salvage, but I at least have the metal bits to bolt the cross beams on. I may be willing to part with the roof rack delete strips I currently have. Not sure yet, have to get the rack installed to make sure I like it.
The stack of wheels next to the air compressor is a set of 17" ARE AR95 Estrellas that I picked up for $50 last year. They are destined to make it on the P5 eventually.
Ok, we'll i guess I made a big assumption. I thought there would be mounting holes for the roof rack runners. It seems that roof rack optioned P5s have the holes drilled and mine does not. I suppose I could drill them but I need to be exact. Damn, there's always something.
