Can anyone who has upgraded their intake verify if have noticed significantly louder turbo sounds? Also any turbo owners try the Borla stype bolt on exhaust?
You won't. You'll just hear more exhausthmmm, then ill leave air box oem, and perhaps use a borla bolt on and maybe ill hear more turbo sound from the exhaust...
They have a solution for that now.you should keep the stock airbox. you will lose low end torque and increase IAT with a short ram.
What's the solution?They have a solution for that now.
But yeah the best is to run it to the fender, which no one makes a kit for.
Yeah there is plenty of room to run a CAI. In fact I want to make something, but I had to put plans on hold for now.Is there even space to draw air from the bumper?
Cool.Yeah there is plenty of room to run a CAI. In fact I want to make something, but I had to put plans on hold for now.
That's why the best performance replacement is the AEM Dryflow type filter, not the K&N oiled type.I've seen various tests done on high flow performance filters and all of them don't filter as well as paper filters. Some paper filters from reputable manufacturers actually flow decently while doing a good job filtering the air. I also don't like the variable of having to clean the cotton/oil filter types which require re-oiling after cleaning/rinsing the filter. I've seen situations where the oil in the cotton filter gets sucked into the intake air and coating the mass air flow meter.
I have been very happy with the Dryflow.That's why the best performance replacement is the AEM Dryflow type filter, not the K&N oiled type.
Nevada, would you say that just swapping out the stock filter for the Dryflow alone would make a significant sound increase without the low end torque hit from the short ram intake?I have been very happy with the Dryflow.
I also popped out the plastic restrictor that surrounds the lower hood latch. This is the source of the air inlet for the stock 2.5 NA airbox. Definitely louder and better air flow into the intake.
