Cx5 p0304 tried everything
Hi guys
I have 2016 cx5 with p0304. It goes to limp mode with ac on and under load.
Me and my mechanic replaced injector-resistance tested, coil, plug, checked wiring, did walnut blasting valves, checked compression, even swapped ECU..still same problem. Getting desperate. Does anyone have any ideas? Thank you
Is there anything else about the electronics that has been modified?
I wonder if it's your alternator? Have you measured the voltage of the battery while running?
Upvote 0
We've seen a lot of issues with aftermarket coil packs on the forum here.
Not a mechanic, but I watch YouTube mechanics such as South Main Auto, Royalty Auto Service, and Rainman Ray.
The amount of times aftermarket parts or knockoff Ebay/Amazon parts cause issues is way too high.
If its something necessary for smooth operation and drivability, stick with OEM from a reputable vendor.
Upvote 0
Just swapped oem plugs, same thing
Upvote 0
