P0304 Error. Help tried everything!
Hi guys
I have 2016 cx5 with p0304. It goes to limp mode with ac on and under load.
Me and my mechanic replaced injector-resistance tested, coil, plug, checked wiring, did walnut blasting valves, checked compression, even swapped ECU..still same problem. Getting desperate. Does anyone have any ideas? Thank you
Is there anything else about the electronics that has been modified?
I wonder if it's your alternator? Have you measured the voltage of the battery while running?
Upvote 0
We've seen a lot of issues with aftermarket coil packs on the forum here.
Not a mechanic, but I watch YouTube mechanics such as South Main Auto, Royalty Auto Service, and Rainman Ray.
The amount of times aftermarket parts or knockoff Ebay/Amazon parts cause issues is way too high.
If its something necessary for smooth operation and drivability, stick with OEM from a reputable vendor.
Upvote 0
Just swapped oem plugs, same thing
Upvote 0
You need to isolate the misfire to determine which cylinder is not firing and why. Below video shows how to do that. My guess is a bad injector coil. Pretty common. If so, Mazda sells them for not much more than Autozone and way more reliable.
Upvote 0
