Loud engine tick
Daughter's 2018 CX-5 with the 2.5 for the past few weeks has been making a very loud (substantially louder than normal at startup) ticking sound. The odd part is it is only happening at startup when she is in the mountains of western north carolina. when home in Raleigh no ticking sound. She works at a park there during the summer and this has happened 4 weeks in a row, but only once or twice a week. Saw a video online where she can run the idle higher and bring it down after a few seconds (essentially revving the engine) and this has worked for her to eliminate the tick after a few rounds of this. I was thinking it was the HLA issue but shouldn't that be at every startup? I religiously change the oil every 5k miles with 0W-20. Thinking of switching it to 5W-30, car has 84k miles on it. I was thinking of taking it to a Mazda dealer here at home when she gets back this week but not sure they will do much to replicate it. Wondering if it is an oil issue of starvation at startup due to the elevation or if it is the HLA issue and is at early onset and that is why it is not every day? I'm lost with this one. Any help/advice would be greatly appreciated. thank you all
The valve ticking noise is due to the original switchable hydraulic lash adjusters used on cylinder #1 and #4 are failing IMO. It’s a common problem on the 2.5L NA with cylinder deactivation and Mazda has revised those switchable HLA’s used for CD to fix the issue. See the TSB:
2018 CX-5 GT Ticking sound?
And:
CX-5 engine rattle
I am leaning that way as well based upon all the research so did, but it just seems odd that it only happens once or twice a week and only when she is up in the mountains. I would have figured it would not be location dependent and happen more frequently- but I guess it could just be coincidental when/where it keeps happening. Appreciate the feedback and help.
Might go away with 5w-30, Chrysler has a similar problem with their hemi engines with CDA, people report the problem going away when bumping up to 5w-30. Can't hurt.
No, it isn’t location dependent but the faulty design of the switchable HLAs which IMO is related to the PCM update to fix the early rocker arm falling problem on cylinder deactivation. If you read the entire thread posted above, and the early Service Alerts and TSBs, you’ll see the early fix of this valve tapping noise is to raise the engine to 2,000 rpm for 5 minutes to get rid of air bubbles accumulated in the oil passage in the switchable HLAs. This means once you actually drive the vehicle, the air bubbles could be gone and the tapping noise would be reduced. Of course this “2,000 rpm for 5 minutes” is a joke and it can never truly fix the problem. Mazda eventually did something as outlined in the latest TSB: “the switchable HLA has been modified for increased oil supply to reduce air bubbles in the oil passage”.
Early Service Alerts and TSBs for Engine Tapping Noise
Here's the most recent TSB on 'Tapping noise from engine', which supersedes all prior communication on this subject. It has additional information, but IMO in no way will make anyone feel happier about owning a 2018-20 Skyactiv-CD engine.
The most important new statement from Mazda in this revised TSB is that 'the switchable HLA has been modified for increased oil supply to reduce air bubbles in the oil passage'. So this certainly sounds like confirmation from the automaker that the factory switchable HLAs are not subject to 'failing', but instead were designed incorrectly by not providing for enough oil flow.
And so the new question question becomes, how many engines will eventually produce whatever set of conditions are required to create the low oil flow, air bubbles, and the noise? Just another episode in the Skyactiv CD horror show.
So if you really want to get rid of the valve tapping noise, the only way is to replace your original switchable HLAs with revised switchable HLAs.
Agreed. But the oil can help for now.
For OP, switching to 5W-30 oil is a cheap way to try. But based on Mazda’s TSB they increased oil supply in modified switchable HLA’s oil passage to reduce air bubbles. Thicker 5W-30 oil may actually achieve opposite result.
5W30 isn't exactly thick enough to impact oil circulation.
Then it won’t be able to increase the oil supply to original switchable HLA oil passage to reduce air bubbles.
We get vehicles right off the truck with that ticking problem and the 2000 rpm for 5 min thing always fixes them
There is nothing extreme about 5W30, and using it will not cause any issues. It is still considered on the thinner side. Most modern engine clearances are fine with even thicker than this.
Is it cooler in the mountains when the car is first started in the morning? Trying a different oil might help. Hard to say what kind of oil would be best.
Although the current owner is maintaining the engine properly, how well was the engine treated by the first owner? How many miles did the car have at the time of purchase?
In the TSB Mazda had admitted the design of the original switchable HLA is faulty which caused air bubbles in the oil passage. They had redesigned the switchable HLA to increase the oil supply to eliminate the problem. This has nothing to do with prior maintenance.
