is there any way i could save it? how much time do i have until the diff fails, do i need a new breather tube?
Where can i buy the revised tube? No i have done the fluid of the diff yet, most def gonna do thatI am not aware of anyone rebuilding these at home.
Sorry.. I don’t know on how long it will last.
Have you drained and refilled the fluid out of the rear diff yet?
I would install the revised breather tube but that will just prevent further damage if water gets into that spot in the future.
Ur a life saver, cant seem to find the rear diff fluid, anything u suggest?
What MY of your CX-5 and how many miles on it? Have you driven through flooding water recently?View attachment 329358
Def looks like there was water in there, f$&k… whats next???
The OP should have seen “4WD” malfunction warning light when his rear differential is having water in there?He has a ‘14… it could have been from a car wash as well..
Mazda has modified the rear differential front housing to eliminate cause of the noise due to bearing failure since Oct. 2015. @Chris_Top_Her had his 2015 rear differential replaced with a used 2016 CX-5 on purpose as it has revised housing:
New diff came in, off aearly build 2016 and the casted model no. is the revised version.
no I used some place from CO because the LKQ yards all wanted 180-280 for freight shipping, and I couldn't find any LKQ listing for one on ebay (LKQ listings on ebay are usually free shipping). Paid like 430 shipped for it. There aren't a lot of these used floating around on the net
Done and done..gonna have my tcm reprogrammed tomorrow with the new diffs text string. Old diff was tore up inside, very black oil but also low viscosity.. it may have had water damage but I've never forced anything (cough uno). So far so good. Also noticed my passenger side brake pad on the caliper side was damn near gone. Probably need to grease slid pins but after two multiple hours sessions I was done wrenching. Contacted brake labs to see if they sell pads only
How many quick packs will i need, just one?Fluid preferences are debatable and borderline on politics & religion……but I use Amsoil in a lot of my applications. This is what I have been using in my CX-5. ‘16+ they started recommending some expensive Mazda fluid for models going forward. Any one of these I would fine using in mine…others will have their own recommendations
The manual says the gear lube capacity at front transfer case is 0.45 quart. The rear differential is 0.45 / 0.37 quarts on gen-1 / gen-2 CX-5 respectively.How many quick packs will i need, just one?
