Have you had many cars, Colorado? Serious.
Like literally every single car I've owned would do this when too much snow gets caught up in the wheel wells.
I had 2 Jeeps before this car. They had different shaking issues LOL!
Did you add at least a couple of more psis than factory recommended 34 psi to your new 225/65R17 102H General AltiMAX RT43s?
Yep, did my homework. They're all at 37psi. Also I made sure I got the H-rated ones instead of the T-rated. Hopefully I'll have some more time to drive it without the kids so I can see if the limits have really changed.
So you know therere both T-rated and H-rated 225/65R17 RT43s and H-rated is much superior on specs, you really have done the home work no doubt!
And 37 psi would be my choice too!
New diff came in, off aearly build 2016 and the casted model no. is the revised version.
Is it from LKQ? How much does it cost?
Mazda SG1 gear lubricant is pretty expensive for 2016 rear differential. Hope this replacement would fix your problem.
no I used some place from CO because the LKQ yards all wanted 180-280 for freight shipping, and I couldn't find any LKQ listing for one on ebay (LKQ listings on ebay are usually free shipping). Paid like 430 shipped for it. There aren't a lot of these used floating around on the net
Still its better than paying $1,000 ~ $1,500 (?) from Mazda dealer.
Curious if you can tell the physical differences on input shaft casing which got modified. Take some pictures for comparison between the two if you can.
Drove down to the dealer in Phoenix this past weekend to have them replace the incorrect second key that they had provided at the purchase and had them install the mudflaps. Considered doing it myself, but it looked like a bit of a PITA so I let them do it for a total cost of $182 including the flaps. Mt time is worth more than that.
Washed ours for probably the first time since I got my Miata back in July. Those front wheels were NASTY!!!
Also verified with my micrometer that the current tires have around 3.5mm tread depth which is right at 4/32.
Might be getting these as a gif to myself in Jan (both part). Should have got them a while back, I can already tell especially when I jack the car effect of metal fatigue
Today I think I will spray my car down with water, it is up to 53 degrees. I want to rinse the salt off.
Done. The beading water from the wax helps a lot when spraying the car down.
Starting messing with diff.. ofc an axle got stuck, which I did end up freeing after buying a slide hammer and still ended up using a crow bar to get the axle free (after I pulled the center part and boot off trying to get it out). Pretty much ready to remove the diff, hold one bolt I'm having trouble breaking due to its loction. But at 230am and ice on my car I called it lol.
Boy youre working too hard ⋯
Good luck on the project, and take some pictures if you can.
Done and done..gonna have my tcm reprogrammed tomorrow with the new diffs text string. Old diff was tore up inside, very black oil but also low viscosity.. it may have had water damage but I've never forced anything (cough uno). So far so good. Also noticed my passenger side brake pad on the caliper side was damn near gone. Probably need to grease slid pins but after two multiple hours sessions I was done wrenching. Contacted brake labs to see if they sell pads only
That's exactly why I use a https://www.amazon.com (commissions earned) for this vehicle. A must have. Toyota/Lexus used an idiotic design for the pinch welds on the 02-06 Lexus ES, so they definitely showed some damage on my car after 10 years. Mazda uses three layers of steel bonded together, which is stronger, but I like using this adapter which lets the metal sit on a UHMW pad backed by aluminum. Pinch welds still look great.
Glad to hear youre done for such a muscle-intensive job. Looks like the only thing could be wrong is the clutch pack, or you should hear major noises from other broken parts. So the TCM, not the PCM needs to know the rear differential ID (I assume thats the differential text string for)? How do you do the TCM re-programming?
That's exactly why I use a pinch weld adapter for this vehicle. A must have. Toyota/Lexus used an idiotic design for the pinch welds on the 02-06 Lexus ES, so they definitely showed some damage on my car after 10 years. Mazda uses three layers of steel bonded together, which is stronger, but I like using this adapter which lets the metal sit on a UHMW pad backed by aluminum. Pinch welds still look great.
I don't think Chris is talking about pinch weld fatigue. I think the metal fatigue he's talking about is the OEM black metal brace in the pic. Likely due to how hard he drives his car. Taking turns aggressively, launches, hard stops, etc. The OEM brace can only take so much, so he's reinforcing it with the new goodies.
Pinch weld adapter isn't necessary. If you're using a floor/garage jack, jack it up at the two designated jacking areas found in the manual. It's faster, more stable, and a lot harder to **** up. After seeing the video below (which I think I may have posted before), I'm sticking to the designated jack points (and 2x4s to drive up on if my car is too low for the jack to fit underneath). Skip to 3:30. Pinch welds should only be used for jacking in emergency situations.
To be fair, the guy did a ton of things wrong, though. Used two hockey pucks, going by what his hand felt instead of using his eyes, continuing to jack the car up even after hearing unusual noises.. yikes. And he was using a pinch weld adapter too.
