For those of you who have the CX-70 can you let us know if the issues reported in the CX-90 forum have been fixed in this release?
TIA
TIA
Assembly issue could cause the steering system to lose power assist, fault with the forward collision warning system, CX-90 has been recalled for a steering issue that could produce an abrupt increase in steering weight, Low speed phantom braking issue, SUV could go into a failsafe mode that leaves drivers stranded on the road, while the CX-90 hybrid's and Mazda3's cameras could flicker.I own a CX70, and am not sure exactly what issues you're referring to? Can you be specific about what you'd like to know? I think the CX70 is an amazing car (read my review post for my thoughts).
My New Red CX-70 I-6 Turbo S Premium Plus
I picked up a new CX70 Soul Red Turbo S Premium Plus, with the beige interior this past Friday. We had two Genesis GV70 and have had too many issues and are working our way to get out from Genesis. One of our GV70, is less than two months old and suffered catastrophic engine failure at 850 miles...mazdas247.com
I've certainly had no such issues whatsoever. If there was a recall for the CX90, one can be pretty much assured since they are pretty much the same car, the CX70 without a 3rd row and the CX70 being newer, any such issues were resolved before they started delivering CX70s to dealerships around the world. The way I see it, the CX70 is a brand new model, but has been through its teething in the CX90 for a year now.Assembly issue could cause the steering system to lose power assist, fault with the forward collision warning system, CX-90 has been recalled for a steering issue that could produce an abrupt increase in steering weight, Low speed phantom braking issue, SUV could go into a failsafe mode that leaves drivers stranded on the road, while the CX-90 hybrid's and Mazda3's cameras could flicker.
These are a few that I was able to find online...
The naysayers are going to be surprised. Mazda, knew exactly what it was doing with the CX70. I know a lot of people who simply have no interest in a 3 row SUV, but want the luxuriousness and inline 6 of the CX90. Two friends I know have already bought one. Another friend is negotiating for one right now. The CX70 is going to be a great seller. It's just too good to not be.I have had a Rhodium White turbo S Premium for just under three weeks. My wife and I have put over a thousand miles on it and so far everything works as it should. Driver personalization can be temperamental but overall it's a definite plus. Last year I test drove a CX-90 turbo preferred and disliked it a lot. I found the drive train to be rather unrefined, especially when compared our former 2023 CX-5 Signature. Mazda has worked some magic because the CX-70 drivetrain is VERY refined. The transmission is smooth and quick. The engine is like silk and silent unless you lean into it. The I-Stop is so smooth that most of the time I can't tell it's doing it's thing. And we I lean into it, it sounds a lot better. CX-70 is exactly what we've wanted. A bigger CX-5. And it's getting better gas mileage than the CX-5 did![]()
Your comments just reinforce what I've heard about the interior of the CX90 being tight!Recently picked up a ‘25 cx-70 turbo S.
Issues encountered so far:
Driver personalization not always confirming me and automatically sets me up as guest like it’s not even trying to confirm identity of who is driving. This should be programmed by the key and not some silly camera. Need to setup alternative appearances with sun glasses to see if it fixes it.
Occasionally music while in radio mode will have no audio even when switch to different FM settings. Fixed by witching to SXM or pandora and then going back to FM radio fixes this.
When switching to sports mode it takes anywhere from 3+ seconds (not instant).
When setting paddle switches to always on. Fix is to hold down the plus paddle shifter to get it back into normal Drive mode.
When exiting car, once I exit vehicle, it doesn’t always auto lock when walking away from car by factory set to 60 seconds with always having to manually lock the door with keys. Set to 30 seconds and 50:50 times is locks.
Have to unlock car to get the tailgate switch to open (near steering wheel). Poor design.
Wireless charging mat to narrow to fit my iPhone pro. I have the iPhone pro (not max).
To shallow center console! Even my old cx-5 had a deeper center console.
Cup holders not big enough to accommodate anything smaller the bottle water. And to close and blocking HVac screen and controls. Also, blocks center HVAC controls.
With most types of phone mounts to air vent, block access to HVAC making it near impossible to access without removing phone and mount.
*Have to remove to access the +\- for fan speed.
No indication on HVAC screen confirming AC is on without have to remove mount to confirm AC which is illuminated.
Long press on panoramic sun roof should be 3 seconds to open up the shade and 5 seconds to full open the shade and sunroof in one go.
Should be able to adjust climate controls when remotely starting the car from app. Also, should not cut ignition when opening driver doo. Should only cut if you try to hit drake prior to pushing start button.
Other than that happy with my purchase.
I agree that the personalization system is a bit odd. I have trained myself to just look at the Infotainment screen when I start the car and it recognizes me every time. It's not that different from Face ID on iPhone, so it works well, when it sees your face. I have used it with sunglasses and it worked.Recently picked up a ‘25 cx-70 turbo S.
For me, it was simple. I wouldn't buy a SUV with three rows. I have absolutely no need for one, ever. So the CX70 was the right choice.Do not have any need for a third row. Would have gladly purchased a CX 50/CX five if it came with the turbo in-line six. But I definitely have need for a larger trunk. The trunk space in the CX five and 50 are a joke! Believe Mazda trunks are far too small but the CX 70 resolve that issue me. Plus the legroom and the ability to make adjustments for the rear seat. Bench was a seller for me to accommodate more comfort for people in the back seats.
Additionally, since you mentioned it, there is no reason why the CX 70/CX 90 are so closely priced. In fact in many markets, the CX 70 is being sold at a higher premium even though it’s only one year newer with less equipment (seats to accommodate 3rd row).
I do like the upgrades to the front rear facia, but feel that the CX 90 has a more classy front & rear end compared to the Honda Civic style fake vents on the front rear on the CX 70. I understand why Mazda differentiated to avoid confusion with CX-90.
Half of those things are just personal preference.Recently picked up a ‘25 cx-70 turbo S.
Shifter is poorly designed rather then the cx-5 easy to understand design to get car into gear, reverse (manual shift mode) versus the gear design in the CX70 & 90.
To shallow center console storage! Even my old cx-5 had a deeper center console.
Long press on panoramic sun roof switch should be 3 seconds to open up the shade and 5 seconds to full open the shade and sunroof in one go.
Should be able to adjust climate controls when remotely starting the car from app. Also, should not cut ignition when opening driver doo. Should only cut if you try to hit brake prior to pushing start button.
Rear cup holders behind 2nd row. Reminds me of the cheap move by dodge near with manual roll up rear winds (freaking bean counters). Should have house power plug/power connector style in truck (bean counters again).
Should have footwell illumination like many premium SUV brands in the $50K+ price range.
Also believe Mazda has over estimated the HP and TQ. Considering many luxury suvs hav less power and smokes the CX-70 Turbo S trim in 0-60 tests.
*Mazda should have included launch control or at least fitted turbo with Dual ball bearing turbo/better match turbo for its High output model rather than just a better tune. Additionally upgraded other components as weep for the up price (~10k) for the tune. Also, upgraded brakes (brembo), larger rear wing, etc would have been nice differentiators over the standard non turbo s.
