pallor
- 2017 CX-5 Touring PEP
Hello.
I am seeking some guidance on the resolution of my issue. I have a 2017 CX-5 Touring FWD (manufactured 7/2017). Mileage is 120k. I have been the only owner.
While driving home this week the Check Engine light came on along with the AT, SBS, and TSC. I did not notice performance issues. I drove home and parked. I restarted the vehicle. Only the CEL came on. No other lights. The next morning I drove to my Mazda dealership for service.
The dealer determined that the P0847 Oil Pressure Switch 2 Circuit Low was the "issue." Their fix was to replace Switch B for $1000, but explained that what I really needed was a new transmission because as they said replacing the Switch would cause slippage due to contaiminaed fluid. The cost for a new transmission from them is $8000. (It is important to add that they did not check my transmission fluid in the inspection. This is a codes diagnostic only.)
They also suggested the patented myriad of things such as every tune up including replacing my wiper blades.
I went to AutoZone and had the code read. Still P0847. Also bought my own OBDII.
In researching I found a TSB on this matter: Service Bulletin Based on that, it appears the suggested fix is to replace BOTH switches (and I assume the ATF because it has to be opened).
I have sent off for Blackstone test kits to see how bad my ATF actually is.
Has anyone here had this issue successfully fixed? And if so what was the actual solution - eg. switch w/ drain and fill cycle or full transmission replacement.
Thank you!
Thank you!
