- Plano, Texas, USA
Cracked cylinder head on Mazda’s SkyActiv-G 2.5L NA with CD and 2.5T has nothing to do with overheating. Even infamous sudden overheating problem on Mazda’s SkyActiv-D 2.2L diesel doesn’t show cracked cylinder head symptom, when the coolant is spraying all over the engine bay!No, our CX-5 has never overheated. We live in northern New England, so our summers are not especially hot. And the vehicle has never been worked particularly hard.
The TSB you mentioned is only for cracked cylinder head on the 2.5T. Mazda has never issued a TSB for the same problem on the 2.5L NA with CD. But the reason for cracked head on the 2.5L NA with CD could be similar, the head strength got compromised when Mazda modified the cylinder head on 2.5L NA for cylinder deactivation, and for turbo. The 2.5L NA with CD engine tear-down video from Ukraine / Russia posted earlier in this thread has exposed the cracked area with 2 mm thin wall which indicates the weakness of the crack area.>> Rampant speculation below <<
I do have one suspicion about what might have contributed to the issue. The TSB mentions that expansion characteristics of the exhaust manifold can put unexpected stress on the cylinder head. I wonder if movement of the exhaust system might also put stress on the head.
Back in July of this year we had a trailer hitch installed on the vehicle, and my mechanic said that to install it he had to disconnect the rear exhaust hanger(s) to drop the muffler out of the way. Given the apparently weak design of these cylinder heads, I wonder if it may have sustained damage during that process.
Last week when the leak started we were hitting mid 20s Fahrenheit overnight and daily high temps in the mid 30s. This was the first cold weather we've had since the hitch was installed. If there were tiny cracks in the head from the exhaust being flexed around, maybe the temperature cycling last week could have caused it to finally fail?
Just a thought. I have no idea whether this contributed at all to the head failure.
/speculation
		 .  I guess the killer for me was that even if Mazda did pick up the tab for the repair, that it would be repaired with the same parts that failed.  So we just...cut bait.  Makes me sick.  We both loved the car, but it was simply financially idiotic to go any further.
