The Daniel Stern site is legit. I've had difficulties with night road vision all my life, and have spent the money. Clip the H9's as shown. It's the best option, unless you buy LED specific housings.
I like the Daniel Stern site. But sometimes we should be more open minded and try something new. I used to be against blindly putting in an LED equivalent into a halogen lamp housing. The reason was the halogen bulb has a small filament making a tiny light source to the reflector which is designed for that. The LED usually comes with a group of chips which makes the light source bigger and longer, and obviously it isn’t an ideal light source for the reflector designed for a tiny light spot. In addition, the group of LED chips have to be clustered on the side of the supporting structure, which will cause some blind spot for the reflector. Using a LED in the projector type headlight also creates problem on focusing to the magnifier lens for the same reason that the light source can’t be as small as the halogen bulb filament.The Daniel Stern site is legit. I've had difficulties with night road vision all my life, and have spent the money. Clip the H9's as shown. It's the best option, unless you buy LED specific housings.
The bad lighting is NOT caused by those LED manufactures, but by the restrictions of the halogen headlight housing design. However, the design of these LEDs have been improved lately to overcome these restrictions. Those manufactures in China are excellent and they can make very high quality products (hint: iPhones, or a luxurious BYD EV with 1,000 km / 621.37-mile range and 10-minute fast charging time) with reasonable prices. If it isn’t because the trade war against China and raised the tariff to additional 25%, we can enjoy even lower prices with good quality products.Your sources, the companies that make those horrid LED things, are biased as well. If they were good, they'd be legal to use. Which, except for that one particular example that I already posted, the Osram Night Breaker LED H4, they're illegal. All of them.
DOT FMVSS guidelines? They may be good in 1950’s but they’re totally outdated! Remember the sealed beam requirement? Remember the ugly “3-dots” on headlight lens requirement for headlight alignment? Remember the wattage restrictions (55W low-beam / 60W high-beam)? Remember the poor light patterns on US headlights comparing to Euro headlights? Remember the low-beam、hign-beam 2-stage requirement? The last guideline (restriction?) on 2-stage low / high beam finally got removed recently after years of effort filing petitions by Audi and Toyota to DOT and NHTSA. We finally should be able to enjoy the latest and greatest LED array headlights like Mazda’s ALH which has been available in other countries for more than 10 years!Also, if you read DSL's entire page, he links to independent lab studies that adhere to FMVSS guidelines showing simple retrofits simply can't be done. Did you read those reports before calling the guy a shill?
I got flashed too many times by oncoming traffic with the factory HID headlights on my BMW and the factory LED headlights on my CX-5. They‘re much brighter and whitish which make oncoming drivers feel like you’re using the high-beams. Besides, the LEDs themselves have nothing to do with low-beam light pattern cut-off, it’s the headlight housing, and they can be adjusted.Well I feel more comfortable trying the H9's and clipping them for now then I do trying LED's in a housing not designed for them, especially since a lot of those reviews said 5 stars light is good, but then they got flashed by oncoming traffic thinking they were using their brights.
“The H9 has a 65w (nominal) filament optimized for maximum luminance and flux at the expense of shorter lifespan. The H11 has a 55w (nominal) filament optimized for long life at the expense of lower luminance and flux. Both bulbs have equal filament precision, etc.”
There’re reports that the headlight wirings are melting due to higher current of 65W after switching from H11 to H9. I personally would choose those “high performance” H11 halogen bulbs, which keep the same wattage for safety reason.
The same on HB3 / 9005 and 9011. 9005 is 60 watt and 9011 is 65 watt, hence 9011 is brighter but the service life will be shorter.
If for some reason you did this and your car were to burn down (unlikely, but possibly over time) (melted wires, etc), don't post on here that you actually put these bulbs in your car because then your insurance company could potentially find you at fault. The internet is a vast resource for insurance companies.
Interesting. OK, well will consider my options.I got flashed too many times by oncoming traffic with the factory HID headlights on my BMW and the factory LED headlights on my CX-5. They‘re much brighter and whitish which make oncoming drivers feel like you’re using the high-beams. Besides, the LEDs themselves have nothing to do with low-beam light pattern cut-off, it’s the headlight housing, and they can be adjusted.
And just remember the reason why the H9 halogen is brighter than H11 halogen is because H9 has higher wattage, 65W, than the H11 which has DOT allowed 55W used on the low beams (see my post above about DOT FMVSS guidelines). In other words, using 65W halogen bulbs on the low beams isn’t “street legal”. I also saw some complaints that the wire to the headlights feeling hot even melting by using the 65W bulb although I believe that’s a bit exaggerating.
These bulbs are still halogen, but a different type of halogen. The 9011's are HIR. No, not HID, HIR. Halogen Infrared. Because they're halogen, they behave perfectly in our factory housings, no mods to the housings whatsoever.2014 CX-5 Touring
Well I was driving home yesterday at night and noticed my light seemed rather dim. Well turned out the left bulb was burned out and the right is on its way. Had these on the car less than a year.
I guess its true, these higher brightness bulbs don't last all that long. I think at this point I'll go back to more standard bulbs and look at some sort of HID/LED replacement housing/lighting in the future.
Speed Test omegle apple iphone 15 pro max
So what are fellow halogen users using? Are you happy with your bulbs?
