So the engine oil is burned during the combustion and not leaked?Mazda Oil Consumption TSB Turbo Engines
Components: ENGINE AND ENGINE COOLING, TIRES, ELECTRICAL SYSTEM
NHTSA ID Number: 10202685
Manufacturer Communication Number: 01-012-21-3832
5 Affected Products
Vehicles
MAKE MODEL YEAR
MAZDA CX-30 2021
MAZDA CX-5 2021
MAZDA CX-9 2021
MAZDA MAZDA3 2021
MAZDA MAZDA6 2021
Summary
Some vehicles may have a LOW ENGINE OIL LEVEL warning message and a CHECK ENGINE light illuminated in the instrument cluster, along with DTC P250F:00 stored in memory. DTC P250F:00 - Engine oil level signal: engine oil level low. Upon inspecting the engine oil level, the level is found to be low and there doesn't appear to be any trace of oil leakage in the engine compartment. This concern usually occurs when the mileage reaches approximately 3,100 - 4,700 miles (5,000 - 7,500km) and may also occur again after replacing or topping off the engine oil. The root cause of this concern has not been identified yet, therefore a repair procedure will be announced at a later date. Since this issue has been reported after a valve stem seal modification, it is very likely that valve stem seal damage is causing oil to leak into the combustion chamber.
Yes, zero leaks. Just burning oil faster than normal apparently due to defective valve stem seals.So the engine oil is burned during the combustion and not leaked?
Here is mines:Yes, zero leaks. Just burning oil faster than normal apparently due to defective valve stem seals.
Yikes, looks like a very technical job which involves taking a lot of the engine apart. Hope the dealer service techs know what they are doing.The first version of the repair TSB for this issue, is now publicly available on NHTSA's website:
TSB 01-011/22
I'm not sure. My low oil warning light came on and I was not yet due for an oil change service so that's why I took it in and was told about the cause since there are no leaks.Here is mines:
Cx5 new:
oil changed at 2,948mi 1/29/22:
checked today (6,900mi) 12/16/22:
Looks good?
That is encouraging. Thank you for sharing.My Mazda 3 had the TSB fix in October. I’ve put 1500 miles on it and the oil level has not moved. It took them a full day but so far so good.
Wow thats the biggest tsb i have seen lolYikes, looks like a very technical job which involves taking a lot of the engine apart. Hope the dealer service techs know what they are doing.
It is the owner’s responsibility to periodically check the oil level in his engine. Waiting until the “too late light” comes on is not being proactive - you should never see the light. Many manufacturers have the “excessive” oil use issue, they often state that using a quart in 650, 1000 or 1500 miles is “normal”.My low oil warning light came on and I was not yet due for an oil change service so that's why I took it in and was told about the cause since there are no leaks.
www.youcanic.com
Yes. agree with your post that drivers need to check their oil but the burning excessive oil is still unacceptable.It is the owner’s responsibility to periodically check the oil level in his engine. Waiting until the “too late light” comes on is not being proactive - you should never see the light. Many manufacturers have the “excessive” oil use issue, they often state that using a quart in 650, 1000 or 1500 miles is “normal”.
Toyota Burns Oil | Excessive Engine Oil Consumption
We hope you find the Toyota Burns Oil | Excessive Engine Oil Consumption guide helpful. Check these troubleshooting and repair guides for more help on your BMW.www.youcanic.com
Some Newer Cars Can Burn Lots of Oil - Consumer Reports
Some newer cars can burn lots of oil, a Consumer Reports investigation has found. Here's how to identify the problem in newer cars and what to do about it.www.consumerreports.org
Is Oil Consumption In Our Vehicles Acceptable and O.K.? - All About Automotive
Oil consumption is when your vehicle’s engine is consuming oil during normal engine operation and that oil passes through the exhaust system. While oil consumption does cause oil loss it is different than an oil leak(s) that can also cause oil loss. Low oil level can lead to loss of oil...allaboutautomotive.com
Wow, yikes is right! It's exactly the kind of procedure I wouldn't want on a car that's a year old, the plan has too many moving parts. I can see why they only want master techs doing this. Everyone is prone to missteps even a master tech.Yikes, looks like a very technical job which involves taking a lot of the engine apart. Hope the dealer service techs know what they are doing.
Both my CX5s had that kind of oil usage.This issue and the TSB has been posted and discussed in CX-5 and CX-9 forums here before:
Low Engine Oil Warning Light on new CX-5
2021 CX-9 burning oil
I certainly won’t be happy about having a new car which consumes a quart of oil per 5K miles. In addition, I’d also be worried about potential coolant leak issue if I had a 2.5T:
Poll 2.5T Coolant Leak/Engine ReplacementP
Agree with you on Mazda trying to make the TSB as good as it can be but the various “Master techs” doing the job can vary greatly so hopefully the TSB will be performed EXACTLY as prescribed!This whole thing has been in progress for over a year, and it's been very interesting to watch it unfold from beginning to end.
When Mazda first discovered the issue sometime last year, I suspect they did quite a bit of internal hand wringing, trying to figure out what their repair strategy was going to be. I think it's fair to say that automakers across the board feel very uneasy about the idea of large-scale, non-routine warranty repair campaigns. They naturally fear getting lots of customer complaints and bad press as a result of repair job failures, some perhaps even resulting in bigger problems than the original issue.
However, with this valve stem issue, Mazda realized that probably a large percentage of these 2021 Turbo engines would ultimately need to be fixed. And the alternative repair choices of engine replacement or cylinder head replacement/repair would likely be a lot more expensive and/or problematic than the new stem seal replacement procedure that they were considering.
They obviously spent lots of time developing the stem seal tool set and procedure, and very likely did quite a few revisions and changes during the testing phase. That they spent so much time developing this completely new repair procedure from scratch is even more noteworthy, considering that they had publicly admitted to this issue way back in 10/2021, and also indicated that a resolution would be delivered. So a loud clock was ticking and there must have been a great deal of pressure from the VPs (with their bonuses at risk) to get this procedure out to the dealers quickly.
I guess someone must have had heavyweight clout, to be able to successfully push back against all of that; and do everything that was necessary to feel as comfortable as possible about what they were developing. One really good indicator of how Mazda feels about this whole thing is the bit about the job being limited to master techs only. And the amazing amount of detail in the procedure (plus video instruction), shows how much effort they put into this. They've obviously tried to do everything possible to make this campaign a complete success, and thus far every stem seal repair report I've read has been positive.
I'm not a Mazda fanboy, or any other automaker for that matter either. However, taking everything into consideration, when it comes to this repair campaign, I'm giving Mazda full credit for doing a very fine job.
Thats why when its time to actually perform the job every dealership or “Master Tech” is different so HOPEFULLY the TSB will be performed as prescribed lolWow, yikes is right! It's exactly the kind of procedure I wouldn't want on a car that's a year old, the plan has too many moving parts. I can see why they only want master techs doing this. Everyone is prone to missteps even a master tech.
My 2016 2.5L NA uses about a half quart of 0W-20 oil per 5K ~ 6K miles, 30% ~ 10% oil life on Flexible OCI. I plan to use 5W-30 GF-6 oil after my current stock of Mazda Moly 0W-20 (GF-5) oil exhausted.Both my CX5s had that kind of oil usage.
