2018 Mazda CX-5 - Speaker replacement
2018 CX-5
Hey guys,
I 'm looking to replace my speakers on my 2018 CX 5, Non Bose 4 speakers.
I've read around with people replacing their speakers with Polk Audio DB652, Hertz DCX 165.3, Rockford Fosgate R165x3, JBL GX602.
My question is, what is the Max depth and height i can use? Because there are speakers on Crutchfield which say that they don't fit my car, but I have read about people installing them in their cars.
I'm thinking of replacing mine with 4x Infinity Kappa 62ix (https://www.infinityspeakers.com/ca...dwvar_KAPPA 62IX___color=Black-GLOBAL-Current).
Do you think these will fit? Will the door panel go back on? Is the window going to open normally? Are any of the speakers mentioned above a better choice?
Thanks in advance!
I don't know if Crutchfield is being conservative or if the measurements for cx5 is wrong but the selection of speakers that fit (according to them) is pretty limited. I have Alpine RS65.2 installed on my front doors (2019) and those aren't supposed to fit according to Crutchfield.
Just select your car and then search for the speakers you like. It will tell you which part doesn't fit (for most speakers I looked at, it says mounting height is the problem) I suspect the mounting height they listed for cx5 is a little off.
There are threads on this site and Youtubes that say to Dremel the centers of the old speakers out leaving the frame and mount new speakers to the old baskets. I haven't done it but I think that method probably gives some latitude as to what speakers can fit.
So the rear speakers are a more standard size?
I removed one of the rear door panels so maybe next I'll do it right.
@Mazdiod2 not more standard size .. more standard mounting :)
basically on the front speakers when you sacrifice them and simply rip the cone/spider out you are using the plastic of the factory speaker to give you some place to mount the replacement speaker to.
If you are crafty you could make what is called a speaker ring
example:
from here: https://www.miataforumz.com/attachm...-doorspeakerringseml1.jpg?dateline=1324096262
Hey guys,
So i went ahead and bought 2x Focal RCX-165 for the front and 2x Hertz DCX 165.3 for the rear. I know it's not optimal, but i couldn't decide between the 2.
I am crafty enough, so I did dremel the original speakers and used the frame for the new speakers. Everything went almost perfect until the last door, I broke the panel in the inside corner(yeah I'm stupid), you'll see it in the pictures, I put some electrical tape for now until i put some black adhesive.
I also broke a few of the clips but i had extras.
I also added an adhesive foam strip between the speaker and the frame to seal the connection a bit better, instead of putting the speaker straight on the plastic.
Now, the speakers are much better than the factory ones, especially highs and mids, the base even went down a little, but it's much cleaner and punchier, but anyway it was already too much.
In general, the clarity is way better and quality wise you hear the difference.
If anyone has any questions, I'll try my best to answer them.
Hey guys,
If anyone has any questions i'll try my best to answer them.
Are you happy with your new speakers. Is there a noticeable difference after driving for a few months?
Hi, sorry it took so long to reply, summer vacation! Anyway, I haven't noticed any difference since I installed the speakers. Is there anything specific you want to know?
I think the question is "You spent time and money on replacement speakers. Did that effort and expense improve the sound quality?" "If you had to do it (speaker replacement) again would you? If not, why?"
Hey,
Yes, it was 100% worth the time and money I spent on the speakers. The effort wasn't as much as I thought it would be and yes, it did improve the sound quality! 😊
I'm Trying Decide What Size Speakers To Order For My 2018 BOSE Equipped CX-5 For My Rear Doors But Cannot Get Conclusive Info On What Size I Need to Buy? Is It 5.25", 6.5", Or Even As Large As 6.75"?
Hi,
Both the speakers I used front and rear were 165mm (6.5").
Hi All,
I have base model cx5 2025 and want to make it sound better. I'm considering to have a budget upgrade without replacing amp.
What do I need to stock up on before replacing the speakers?
My thoughts are as follows:
- x4 6.5” speakers. Ideally more bass on the back and more clear sound to the front doors.
- Plastic spatulas for removing door cards.
- Double sided tape (mentioned by the author)
- Snap clips in case something breaks.
- Screwdrivers
A few questions remain:
1. Will the standard system be able to give sound to mid-range speakers from amazon without an additional amplifier?
2. Do I need wire clips on the wires? Which ones?
3. If I forget something, I'd happy to hear your thoughts
Thx!
New Threads
