2016.5 CX-5 Speaker Replacement/Upgrade
I figured that. I may just go with the stock replacement.
Just be careful on those plastic clips on door panels. And you may have to drill the rivets out which are used to hold the Bose door woofers if I remember it correctly.
will do thank you. Appreciate all the help, these forums are a great place for info and help.
Give us an update such as if the rivets are used (?) or the front door speaker mount bracket p/n KD45-66-A61 can be reused, etc., after you replaced the OEM Bose woofer with a couple of pictures that would be great.
