2014 CX-5 Driver's side window not operating
The window in my cx-5 doesn't open or close. I have replaced the motor and switch assembly and it still doesn't operate. Anyone have any suggestions to the fix?
Total shot in the dark: Did you check the fuses? My 2020 manual shows four fuses for power windows spread across the two fuse blocks.
You don't say how old your car is, but it could just be that the window regulator has gone bad.
When I connect a new motor and switch, press up or down, the motor gear doesn't turn. I get nothing, dead silence. BTW it's a 2014 cx-5.
You need a multimeter to check the electricity. Check first if you do have power to feed the switch and motor with ignition on but the engine is not running.
