- Mazda Protege DX
oh? the 2.5L Turbo calls for 5w30 not 0w20 like the regular cx5BTW, we can tell your engine is not U.S.--the oil cap is marked 5W-30.![]()
mine scan tool used to read 200+ but mazda updated the pcm to the newest ver, that must of change all the datapoint so it no longer works.Also, you can download (Windows) or cellphone app of Forscan, and use it with a bluetooth or USB OBD adapter (what I do). Forscan isn't as user friendly as Torque, but it reads all sorts of basic and advanced PID's, including misfire counters. With the PC version + $25 USB OBD adapter, mine reads 250+ PIDS/sec.
oh wow interesting, i thought mazda only used 5w30 for the turbo engines to prevent fuel dilution and such, i guess it depends on climate and location tooI recall the non-U.S. normally aspirated calls for 5w-30. Mine isn't turbo, and says 0w-20 on the cap, although being in Texas I use 5w-30.
unfortunately it is how things are now, flat rate is ruining things for everyone, a tech needs time to diag but sadly warranty time just does not pay enough, spending hours to find a problem only to find it was the coil that caused the problem and only getting paid .5 hour to replace.I have sadly discovered that employment statistics also apply to service techs; 75% are average ability or worse. 10% are very good, and 1% top notch and the kind you want when doing detailed diagnostics. The likelihood you have one of those at your dealerships, is, well....
Mazda recommends 5W-30 oil for 2.5T ⋯BTW, we can tell your engine is not U.S.--the oil cap is marked 5W-30.![]()
Mazda recommends 0W-20 oil for naturally aspirated 2.0L / 2.5L in the US, but more choices in other areas:I recall the non-U.S. normally aspirated calls for 5w-30. Mine isn't turbo, and says 0w-20 on the cap, although being in Texas I use 5w-30.
well honestly the rough idle u can feel easily, but i feel they dont want look into it further unless the code comes back again, after all they did update the pcm software without even telling meI don't think they swapped coils because they couldn't reproduce the issue and asked you to monitor it. Why work on an issue they can't reproduce.
yeah.. well i might take off my intake manifold to see how much build up there islol carbon cleaning service.. you should do that for a USD $10 can (you don't even need to use the whole can).. prior to every oil change
Would you think possible carbon build up on intake valve would cause this as well?One thing I noticed on your freeze frame was an unusually high 3.19 g/s MAF reading for 550 RPM. Would expect about 2 g/s. Combined with a somewhat low MAP reading (-17 in vacuum, but expect -19 to- 21 in), and an unusually high 31% load (expect < 25%), but somewhat high 12% throttle position (should be 5 or 5%) and OK fuel trims, I might suspect something like stuck open PCV; large bypass flow, low in 02 content (crankcase blowby). Or some additional engine load that isn't kicking the RPM up (A/C, transmission in gear *would* cause the RPM to boost))
At 15K miles? I really don’t think so.Would you think possible carbon build up on intake valve would cause this as well?
91 always since new.At 15K miles? I really don’t think so.
Do you use top-tier gas?
i see, thank you for your insight. currently im just waiting for the check engine light to come backWouldn't think so for 15k miles. I haven't seen data from a known carbon restricted GDI engine, but would guess lower than normal MAF along with lumpy idle.
Top tier gas doesn't matter on GDI, regarding valve carbon. Fuel doesn't get sprayed on the lower intake and back of valves like port injected.
