No Crank, No Start, Help Please!
If your engine doesn't turn over then coils have nothing to do with your problem.
Tr switches have a tendency to wear out intermittently...
Yours died all of a sudden...
That leads me to think that he shifter cable may have fallen off or broken.. (unless the physical contact inside the switch just fell apart)
Hmm Okay, I might try then.. I just didn't understand the whole aligning of the TR switch.
Where is the shifter cable?
http://web.archive.org/web/20050227015339/http://protege5.ugly.net:80/05-18.PDF
Read through the two chapters to familiarize yourself with it then see what's under your car. (I've never seen it... my car's a manual.)
6) The next thing I will try to do on Thursday will be, new ignition coil's and new a new starter relay just in case. Even though I tested it and heard click noise.!
When you say starter relay, do you mean this ???
Part #3 ??
The big ass solenoid on top of the starter motor ??
I'm having a hard time finding "starter relay" in the manual...
K... So if this was my car, and it suddenly wouldn't start and I had an automatic (Eeeeeeww)...
I would trace the wire from the starter motor..
The B/Y wire should be +12 V with the key in start position.
Follow that to the B/Y wire coming out of the Transaxle Range switch and check for +12 V...
Then I would check for +12 V going INTO the TR switch on the B/L wire.. (start wire from the ignition switch).
Depending on where the +12 V stops, you can find the problem and eliminate many possible parts replacements.
Your problem may be simply a bad connection or break along that wire.
If you've got+12 V going into your TR switch but not coming out (in P or N) then your TR Switch is faulty.
REMEMBER !!! This is only if I had an Automatic... Which I do not... Eeeeeww.
Part #3 ??
Sorry I used wrong term. I meant the starter relay switch, like the big one in the fuse box, I thought that's what its called.
But another update...
I replaced the neutral safety switch.. still doesn't start. So I have done replaced the starter motor/solenoid, the ignition switch, the neutral safety switch.
So after I replace that fuse tomorrow, pretty sure I'll be taking it to mechanic.. don't know what the hell else is wrong.
You may want to take it to a Mazda mechanic...
They may charge more but they may know exactly what's wrong and how to fix it.
Or show him this thread to give him a head start.
... I meant the starter relay switch, like the big one in the fuse box, I thought that's what its called...
I'm still not seeing it ???
I did hear a relay clicking when I turned my key to start without the clutch depressed but it was from the right side of the passenger foot well..
PS..
Right at 2:10 he mentions the 100 Amp main fuse..
That damn thing bolts in..
You have to unbolt the entire fusebox, lift it up, unbolt the burnt fuse and bolt in a new one...
What a PITA...
I've blown it twice...
Remember...
You're talking about a car that doesn't even crank...
Not a car that won't run...
I personally would do what the FSM Says to do about it...
"Open starter circuit between ignition key and starter"
Check for a broken/disconnected/bad connected wire...
Trace the TR switch for continuity.
PS..
What a PITA...
You are right.. that is fuel pump relay.. I got some miss information... Wait so this 100amp fuse.. I didn't check that... Will that prevent car from starting???? Thanks.
So my last question.. where is the ingition relay or starter relay.. does this car have one?? I haven't checked those.. I got confused with that fuel pump relay.
No... That fuse will prevent your car from doing anything.
It's like not having a battery...
What about the main relay?? I was doing some reading on that... Do you it's worth to try that before taking it in.. only $25 bucks.
