- 2024 CX5 Akera G25
Exactly. Unfortunately there're many senior citizens in the US are getting CX-5's.
People if they read these procedures like I did, (and thanks for many detailed documents on SA-D) they would definitely have a second thought of getting a SkyActiv-D diesel, such as this Compulsory DPF regeneration in the long mode: (PM = particulate matter)
Ive had CX5 diesels since 2013. Never once have I had a blocked DPF necessitating a forced regen. My brother has one as well and he says the same, even though his car does mainly local running and is now 5 years old.
The DPF was repositioned closer to the engine in the 2015 MY and since then, my local dealer says they have seen no blocked DPF's.
I do note however that here in Aus we have nationally enforced diesel fuel quality standards so there is basically no difference in quality between retail fuel brands. If you use crap fuel then you might get issues.
So dont over dramatise this. Its rarely an issue in practice. Mazda dealers here as a matter of course will ask you about your driving habits and anticipated annual mileage if you ask about a diesel, and will recommend a petrol engine when appropriate.
So no matter how much Mazda has done to prevent the oil dilution (raising) issue, it potential still can happen. That's why the additional "X" mark on the oil dipstick. Unfortunately most US car owners aren't getting used to use "Flexible" oil change interval with oil life monitor, I can see this's going to be a challenge to overcome on oil change practice for diesel owners and Mazda dealers as most of them use fixed OCI!
Similarly, I have never had excessive diesel in the oil issues, in fact I have barely noticed the oil level change at all. I check it maybe monthly. My brother's 2012 CX5 had a few issues early 2012/13 until Mazda released updated the engine management software and added the new dipstick design - since then, no issues. Can it be an issue? Yes, albeit only in a small number of cases.
This right here will be an impossible task for Mazda North American Operations who can mandate a 0W-30 C3 diesel oil as the only oil Mazda diesel owner's can use, because they can't!
Mandate it maybe no. Deny warranty if you dont use it - yes they will.
If you use a oil that does not meet the manufacturer's specifications, especially after being specifically told how important it is, I have no doubt they will deny engine warranty when anything related goes wrong. And, it will go wrong if you dont use an oil that meets specs.
No different to using an aftermarket part that doesnt meet manufacturer's specs that causes a failure - no warranty.
Here Mazda specifies a full synth 5W-30 that meets JASO DL-1 or ACEA C-1. No doubt they will be very clear about the required oil specifications when the diesel engine is released in the USA.
Yes, people need to have commitment to enjoy a Mazda CX-5 diesel, especially in the US!
So from my personal experience since 2013, the reality of CX5 diesel ownership is hardly any different to owning a petrol engined version. Except trips to the gas station are less frequent and the torque is amazing!
The addition of adblue in the US will hardly change that, its cheap, and infrequent fills will be required.
