- 2016 CX-5
Hi, I searched and couldn't find a how to on this so I figured i do a write-up to help anyone in the same situation.....
First thing I did was check the CX-5 service guide for unclogging procedure,
there was none, but there was a diagram of where the drain hose was,
it's behind the panel by the passenger left shin:
Next step was to remove the plastic panel, it is very easy, pops right off.
this is the rubber drain hose, you can see it's connected to a white plastic type barb connector:
Then I followed the drain exit point to under the car and determined where the white plastic barb connector comes out from underneath, I jacked up the car and crawled to the approximate location and to my disappointment the drain was unreachable, it's behind a heatshield that is not easily removed or bent out of the way.
So it was back to the top and try to unclog from inside the car,
make sure to clamp the rubber hose first before pulling the rubber hose out from the barb connector
make sure to get a bucket or container to catch the water:
Remove clamp and if there's no water, spray compressed air up hose and be prepared for water to flow out, clamp if you need to empty catch container
also, make sure to clear out any debris in the white barb connector:
Next, if you have musty mildew smell, spray some Kool-It (from Amazon) to get some foaming action into the evaporator coils to clean out any fungus or bacteria that has accumulated due to stagnant water.
Finally, just reassemble and reconnect the rubber hose to the barb, I added a zip tie just in case it clogs again, I wanted to make sure no water leaked thru the fitting.
Also, check your cabin filter do make sure it's clean, replace if it's dirty, can't believe dealers charge $90 for this, scum thieves, how do they sleep at night knowing they rip people off
