- Plano, Texas, USA
People in need of new set of tires for CX-5 GT are facing limited selections on 225/55R19 99V tires.  If you're willing to settle for H rated tire, there're a lot more tires would be available, with many non-name-brands.  But I only listed a few name brand H-rated tires which also ranked highly from reviews by TireRack.com, as others have similar price range at $160+ and they're not worth the money IMHO.  Personally I'd get H rated tires without any hesitation as CX-5 Sport and Touring are using 17" H rated tires from factory.  But if you insist to use V rated 19" tires and would like to save money, thanks to Buzzer777, Nitto NT850+ CUV is the lowest priced tire on the market with decent reputation as it owned by Toyo, for around $130+ each.  You can order this Nitto NT850+ CUV tire from your local tire store such as Discount Tire and it should cost you less than $650 with sales tax, installation, lifetime tire balancing and rotating.  If money is not your concern, Michelin Premier LTX is the most expensive tire, not including OEM Toyo A23, with excellent reviews.  But the drawback, in addition to the high price, is the low maximum inflation pressure at 44 psi while others, including the OEM Toyo A23, are at 51 psi.  This is fairly close to our factory recommended tire pressure at 36 psi, and this is also an indication that the tire structure designed is not as strong as others.
Edit: There's a more recent tire comparison table in post #76.
Grand/Standard Touring All-Season Tires:
[table="width: 780, class: grid"]
[tr]
[td]
Tire[/td]
[td]
Size[/td]
[td]
UTQG[/td]
[td]Maximum
Inflation
Pressure[/td]
[td]
Tread
Depth[/td]
[td]
Tire
Weight[/td]
[td]
Warranty[/td]
[td]
Price*[/td]
[/tr]
[tr]
[td]Toyo A23[/td]
[td]225/55R19
99V[/td]
[td]300 A A[/td]
[td]51 psi[/td]
[td]9.8/32"[/td]
[td]28 lbs.[/td]
[td]OEM - None[/td]
[td]$269.31
- TR[/td]
[/tr]
[tr]
[td]Toyo Versado CUV[/td]
[td]225/55R19
99V[/td]
[td]440 A A[/td]
[td]51 psi[/td]
[td]10.2/32"[/td]
[td]28 lbs.[/td]
[td]50,000 Miles[/td]
[td]$185.34
- TD[/td]
[/tr]
[tr]
[td]Yokohama YK580[/td]
[td]225/55R19
99V[/td]
[td]580 A A[/td]
[td]51 psi[/td]
[td]11/32"[/td]
[td]28.8 lbs.[/td]
[td]60,000 Miles[/td]
[td]$166.00
- DT[/td]
[/tr]
[tr]
[td]Yokohama YK740 GTX[/td]
[td]225/55R19
99V[/td]
[td]740 A A[/td]
[td]51 psi[/td]
[td]12/32"[/td]
[td]29.1 lbs.[/td]
[td]$167.00
- DT[/td]
[/tr]
[tr]
[td]Nitto NT850+ CUV[/td]
[td]225/55R19
99V[/td]
[td]500 A A[/td]
[td]51 psi[/td]
[td]10.6/32"[/td]
[td]? lbs.[/td]
[td]$136.99
- TB[/td]
[/tr]
[tr]
[td]Nitto NT421Q[/td]
[td]225/55R19
103V XL*[/td]
[td]640 A A[/td]
[td]50 psi[/td]
[td]11.8/32"[/td]
[td]? lbs.[/td]
[td]75,000 Miles[/td]
[td]$168.00
- DT[/td]
[/tr]
[tr]
[td]Continental TrueContact[/td]
[td]225/55R19
99H[/td]
[td]800 A A[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]25 lbs.[/td]
[td]90,000 Miles
6 Years[/td]
[td]$168.55
- TR[/td]
[/tr]
[tr]
[td]General AltiMAX RT43[/td]
[td]225/55R19
99H[/td]
[td]700 A A[/td]
[td]51 psi[/td]
[td]?[/td]
[td]24.4 lbs.[/td]
[td]65,000 Miles
6 Years[/td]
[td]$167.55
- TR[/td]
[/tr]
[tr]
[td]Pirelli Cinturato P7
All Season Plus[/td]
[td]225/55R19
99H[/td]
[td]700 A A[/td]
[td]44 psi[/td]
[td]10/32"[/td]
[td]28 lbs.[/td]
[td]70,000 Miles[/td]
[td]$172.55
- TR[/td]
[/tr]
[/table]
Crossover/SUV Touring All-Season Tires:
[tr]
[td]
Tire[/td]
[td]
Size[/td]
[td]
UTQG[/td]
[td]Maximum
Inflation
Pressure[/td]
[td]
Tread
Depth[/td]
[td]
Tire
Weight[/td]
[td]
Warranty[/td]
[td]
Price*[/td]
[/tr]
[tr]
[td]Michelin Premier LTX[/td]
[td]225/55R19
99V[/td]
[td]620 A A[/td]
[td]44 psi[/td]
[td]8.5/32"[/td]
[td]27.34 lbs.[/td]
[td]60,000 Miles
6 Years[/td]
[td]$198.55
- TR[/td]
[/tr]
[tr]
[td]Bridgestone Dueler H/L 422
Ecopia[/td]
[td]225/55R19
99V[/td]
[td]640 A A[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]25 lbs.[/td]
[td]65,000 Miles
5 Years[/td]
[td]$186.55
- TR[/td]
[/tr]
[tr]
[td]Yokohama Geolandar G055[/td]
[td]225/55R19
99V[/td]
[td]740 A A[/td]
[td]51 psi[/td]
[td]11/32"[/td]
[td]28.1 lbs.[/td]
[td]65,000 Miles
5 Years[/td]
[td]$168.55
- TR[/td]
[/tr]
[tr]
[td]Goodyear Assurance CS
Fuel Max[/td]
[td]225/55R19
99H[/td]
[td]600 A B[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]31 lbs.[/td]
[td]65,000 Miles
6 Years[/td]
[td]$196.55
- TR[/td]
[/tr]
[/table]
XL = Extra Load
TR = TireRack.com
DT = DiscountTire.com
TD = TiresDirect.net
TB = TireBuyer.com
Performance Category Rank from TireRack.com:
Grand Touring All-Season Tires:
Pirelli Cinturato P7 All Season Plus - #1 out of 42
General AltiMAX RT43 - #5 out of 42
Continental TrueContact - #1 out of 21
Michelin Premier LTX - #1 out of 24
Bridgestone Dueler H/L 422 Ecopia - #7 out of 24
Yokohama Geolandar G055 - #11 out of 24
Goodyear Assurance CS Fuel Max - #14 out of 24
Other tires are not ranked due to insufficient data or not carried by TireRack.com.
[tr]
[td]
Tire[/td]
[td]
Size[/td]
[td]
UTQG[/td]
[td]Maximum
Inflation
Pressure[/td]
[td]
Tread
Depth[/td]
[td]
Tire
Weight[/td]
[td]
Warranty[/td]
[td]
Price*[/td]
[/tr]
[tr]
[td]Toyo A23[/td]
[td]225/55R19
99V[/td]
[td]300 A A[/td]
[td]51 psi[/td]
[td]9.8/32"[/td]
[td]28 lbs.[/td]
[td]OEM - None[/td]
[td]$269.31
- TR[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]440 A A[/td]
[td]51 psi[/td]
[td]10.2/32"[/td]
[td]28 lbs.[/td]
[td]$185.34
- TD[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]580 A A[/td]
[td]51 psi[/td]
[td]11/32"[/td]
[td]28.8 lbs.[/td]
[td]$166.00
- DT[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]740 A A[/td]
[td]51 psi[/td]
[td]12/32"[/td]
[td]29.1 lbs.[/td]
[td]$167.00
- DT[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]500 A A[/td]
[td]51 psi[/td]
[td]10.6/32"[/td]
[td]? lbs.[/td]
[td]$136.99
- TB[/td]
[/tr]
[tr]
[td]225/55R19
103V XL*[/td]
[td]640 A A[/td]
[td]50 psi[/td]
[td]11.8/32"[/td]
[td]? lbs.[/td]
[td]$168.00
- DT[/td]
[/tr]
[tr]
[td]225/55R19
99H[/td]
[td]800 A A[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]25 lbs.[/td]
[td]90,000 Miles
6 Years[/td]
[td]$168.55
- TR[/td]
[/tr]
[tr]
[td]225/55R19
99H[/td]
[td]700 A A[/td]
[td]51 psi[/td]
[td]?[/td]
[td]24.4 lbs.[/td]
[td]65,000 Miles
6 Years[/td]
[td]$167.55
- TR[/td]
[/tr]
[tr]
[td]225/55R19
99H[/td]
[td]700 A A[/td]
[td]44 psi[/td]
[td]10/32"[/td]
[td]28 lbs.[/td]
[td]$172.55
- TR[/td]
[/tr]
[/table]
[tr]
[td]
Tire[/td]
[td]
Size[/td]
[td]
UTQG[/td]
[td]Maximum
Inflation
Pressure[/td]
[td]
Tread
Depth[/td]
[td]
Tire
Weight[/td]
[td]
Warranty[/td]
[td]
Price*[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]620 A A[/td]
[td]44 psi[/td]
[td]8.5/32"[/td]
[td]27.34 lbs.[/td]
[td]60,000 Miles
6 Years[/td]
[td]$198.55
- TR[/td]
[/tr]
[tr]
Ecopia[/td]
[td]225/55R19
99V[/td]
[td]640 A A[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]25 lbs.[/td]
[td]65,000 Miles
5 Years[/td]
[td]$186.55
- TR[/td]
[/tr]
[tr]
[td]225/55R19
99V[/td]
[td]740 A A[/td]
[td]51 psi[/td]
[td]11/32"[/td]
[td]28.1 lbs.[/td]
[td]65,000 Miles
5 Years[/td]
[td]$168.55
- TR[/td]
[/tr]
[tr]
Fuel Max[/td]
[td]225/55R19
99H[/td]
[td]600 A B[/td]
[td]51 psi[/td]
[td]10/32"[/td]
[td]31 lbs.[/td]
[td]65,000 Miles
6 Years[/td]
[td]$196.55
- TR[/td]
[/tr]
[/table]
XL = Extra Load
TR = TireRack.com
TB = TireBuyer.com
