- RDX Aspec Adv.
^runs cooler, more powa!
If you have any concerns, just pop off the insulation underneath the hood and take a look at the adhesive points attaching the sheet metal to the hood frame, comes off relatively easy. Mine were all broken when I bought the car. I finally took it in before the bumper to bumper warranty expired WITHOUT the insulation. It kind of forced them to say "yeah, there's a problem", rather than it looks normal. Nice and solid now with no flutter.I've been Noticing vibration in the hood on my 2016 when traveling at higher speeds, 60+mph. I know this TSB is for older models but has anyone seen hood vibration on a newer model? What is considered normal amount of hood movement?
Actually, there were two TSBs for the earlier models. Mine was supposedly covered by the first one before I bought the vehicle, so the dealer told me. The later one used a better kind of adhesive. I don't know what defines "normal" amount of hood movement.^^^Good Suggestion^^^ I will pull the insulation off and take a look. I was just wondering if anyone else with a 2016 had experienced any problems. I know the TSB is for 2012-2015 models I believe, but since mine is a very early 2016 there may have been some missed VIN's in the TSB. what is considered normal amount of hood movement?
So does the second tsb cover the 2016s? Anyone know where to find that?
Haven't noticed any flutter on the hood from our 2016 CX-5 but ours seldom drives on the highway. I was surprised yours till have such issue as I thought Mazda should have fixed this simple problem after two TSBs. May be you should take your CX-5 to the dealer without insulation like madar did.Well I took the liner of the hood off today to take a look and found that three of the "glue" point that are right near the windshield are broken. I believe this is what is causing my hood vibrations. Honestly, there's not a whole lot holding the support to the hood. I will bring it up at my next oil change.
If you're still covered under your bumper to bumper warranty they should take care of it.Well I took the liner of the hood off today to take a look and found that three of the "glue" point that are right near the windshield are broken. I believe this is what is causing my hood vibrations. Honestly, there's not a whole lot holding the support to the hood. I will bring it up at my next oil change.
Pictures:
