- RDX Aspec Adv.
The Trans tune slightly bogs down under certain conditions.
Sent from my SM-G900T using Tapatalk
I made a short video tutorial that can help.
Best thing you've ever posted! Not kidding.
You could have made it better by showing how it will hold a high gear if you gradually and very slowly tip into the throttle, even if you eventually tip in quite deep.
This is the "problem" a couple of people have complained about but it's there for a reason. On a long gentle grade the driver might not be aware of exactly how deep (or shallow) the pedal is depressed. So a gradual and slow tip in will not effect an unexpected downshift. If the driver has been pussy-footing the pedal slowly deeper and deeper but now wants a downshift, it may be necessary to ease off the pedal a little and then make a sharper request for power. I quickly learned not to tip the pedal in too slowly if I want a different gear. I love this feature.
This video should be filed under "Driving 101". In your next video you can demonstrate proper use of the brake pedal. (wink)
This is funny!
Are we people really dumb as Mike the Genius? Please!!! I agree with the other guy. Its either push hard or not with No in between. If you're in traffic are you really gonna push it hard!
Oh noIts the nature of an sporty CUV. Guess what? Who the hell pushes a CUV over 70mph on a winding road? It will rollover!!
C'mon, the truth is theres a lot to improve on this car and everyone just praises this POS and believing this is the best happned since the slice bread.
This is funny!
I can. I've partook in cruises where I was able to keep up with miatas and 3s on windy routes. I've improved the handling of mine while keeping it practical for my daily needs.
I think it more likely that you kept up with the DRIVERS of Miatas and 3's...people really have no CLUE how much skill actually comes into play on a "real" track or curvy road.
I'd say not, there is actually an SACA chapter here in town and they often do events not even 5 miles from my house.
So you're saying that your CX-5 is a more capable vehicle than a Miata, given equal drivers?
I don't see how that's possible given the power to weight ratios and centers of gravity. But who knows
Here is a demo of the brake pedal and how it affects the shifting of the transmission.
That's a very advanced video for those just learning how accelerator pedal motion affects gear selection. When I recommended a video on learning to use the brake pedal I was envisioning a beginning tutorial on how to best use the brake pedal to slow or stop the vehicle (for those unfamiliar with the basics). Braking 101.
The CX-5 has state of the art roll-over protection built-in to the Dynamic Stability Control (DSC). Using gyroscopes that can detect the rate of yaw and roll it constantly compares this data with the wheel speed sensors, steering wheel angle, throttle position, brake, etc. If the DSC calculates there is an impending roll-over it intervenes and takes various actions to avert roll-over (such as applying individual brakes to stabilize chassis motion before roll-over occurs). This all happens in 1/100ths of a second. While it cannot prevent rollovers caused by driving into a ditch at an angle or over an embankment, it can prevent the most common type of SUV roll-over such as that caused by avoidance maneuvers or excessively spirited driving.
I've driven the CX-5 in a spirited manner at 90-100 mph in the mountains pushing corners hard and the DSC system did not intervene and the vehicle did not exhibit a tendency to roll-over. Is it a Mazda Miata? Of course not. But your typical driver would have a very tough time (if not impossible) getting it to roll-over just from pushing it 70 mph on a twisty road. Yes, if you drive it off an embankment or slide it into a curb it can roll-over but not simply from spirited driving on a twisty road. Your claim shows a lack of knowledge of the capabilities built into every CX-5 and makes me question your motives.
Agreed. Its pretty hard to roll over this vehicle, with its excellent handling, chassis and stability control system.
I do not recommend following my example.
