CX5- body panel material?
The entire unibody is steel on the 370Z. The doors, hood, and hatchback are aluminum.
That's what I meant: "Stuff that a rock could hit". I should have been more clear, but I was going with the spirit of the title "Body panel material...."
My Z06, though, that was 100% aluminum as far as I know, aside from maybe fasteners and bolts and a few hard-points.
No, body panels on Corvette started with fiberglass material and resin. Later it added SMC plastic and carbon fiber. Z06 does have aluminum-based chassis. We're joking back to the old days that if you crash a Corvette, you'll be sitting on the ground as all fiberglass body panels would be disintegrated!
"The introduction of the C6 Z06 in 2006 brought an aluminum-based chassis structure and a greater percentage of carbon fiber body panels, representing the most significant advanced materials initiative in Corvette history. Despite looking like the steel chassis of the base Corvette, the C6 Z06s aluminum frame weighs nearly one-third less. Magnesium is used for the roof structure, engine cradle and some of the other suspension attachment points for greater mass reduction. On the outside, the Z06 uses carbon fiber panels for the front fenders, front wheel houses and rear fenders."
"The introduction of the C6 Z06 in 2006 brought an aluminum-based chassis structure and a greater percentage of carbon fiber body panels, representing the most significant advanced materials initiative in Corvette history. Despite looking like the steel chassis of the base Corvette, the C6 Z06’s aluminum frame weighs nearly one-third less. Magnesium is used for the roof structure, engine cradle and some of the other suspension attachment points for greater mass reduction. On the outside, the Z06 uses carbon fiber panels for the front fenders, front wheel houses and rear fenders."
Yes, and the front left fender was a $1700 item. Cracked on delivery. Carbon fiber. I watched them build my car from the frame up. I was referring to the chassis, in that case. I do need to clarify better. Anyway, yes, that's pretty accurate on sitting on the ground. My friend flipped his 3x. However, he was just fine. Small scar/scratch. passenger was fine, too. No injury at all. Corvettes are awesome like that. Nearly every high speed wreck results in a walk-away.
