- -- 03 P5 / 23 CX-5 --
the doc B oil system?
Found out my HID converted oem fogs have no place to be running the MSP lip. Not modding lip for them and too big to fit on either side of license plate behind lower grill soooooooooooooooo......probably gonna sell the setup. BUT.............found these and will be checking to see if they can he hacked a bit to fit in place of delete grills. Gonna make something that can be HID work in place of or with modded deletes.
http://www.ebay.com/itm/191258138599?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
So, the MSP lip I just bought won't fit with OEM fogs in place unless I modify it?
Also ditching the oem horn for supertones.....
Also looking at these......and no, won't be using the 8000k bulbs. I has 5000k and 3000k bulbs to use already. Just after some suitable housings.Lemme know which hid housings you end up with. I was gonna use my deletes but hid fogs wouod be better.
.......to go in here......................
Weapon R.......this one wasn't really set up right for coolant to go back and forth due to port being up on top but pushed a piece of silicone vacuum hose thru the port down to bottom of the jug and it pulls back and forth just fine. They have ones with port on bottom but they did not have site glass to see lvl inside. They also have different shaped ones (more expensive too) that do have sight glass and port on bottom of jug. The smaller can to the left is my catch can and it is OBX. I have since relocated it behind the battery by the wiper motor just so it wasn't so cramped in that area under the intake tube and so hoses weren't so crammed upintheya................What catch can/reservoir is that?
