A/c turns on bby itself
Replace the front blower relay, mine was doing this until I replaced it. I got my replacement part from my local Mazda Dealer for $9.80 and it took me 2 minutes to install the new relay.
makan.dm,
here you go: http://blog.yagelski.com/2011/10/mazda-cx-9-blower-motor-stays-on-after.html
updated and latest Mazda part number L1Y167730 you need (qty. 2 one for front and one for rear) very easy fix
ebay $3.79 each shipped :
http://www.ebay.com/itm/MAZDA-OEM-10-12-CX-9-Blower-Motor-Relay-L1Y167730-/161564221862?hash=item259dfa61a6&vxp=mtr
It's highway robbery what dealers charge for this simple fix.
This looks like it would fix your issue. Good find @avidien
It could stay on for 30 secs max.
Replace the two relays. Common issue.
I thought new model years have relays that were better designed.
Hmmm..
Hmmm..
OP's 9 is an '07... I don't expect any blower issues, plus warranty :)
Sorry. Did not see the OP's model.
Relays are common problem to '07 and early '08 like mine.
After replacing mine, never happened again for the following 5 years.
Hello everyone.
regarding this detail of the relays fans, a very fast and avoid buying possible solution is to remove and gently light shocks with a screwdriver ... and ready goodbye problem!
if symptoms persist ... repeat dose or renovate parts.
Greetings.
