A/c turns on bby itself
Replace the front blower relay, mine was doing this until I replaced it. I got my replacement part from my local Mazda Dealer for $9.80 and it took me 2 minutes to install the new relay.
It could stay on for 30 secs max.
Replace the two relays. Common issue.
I thought new model years have relays that were better designed.
Hmmm..
Hmmm..
OP's 9 is an '07... I don't expect any blower issues, plus warranty :)
Sorry. Did not see the OP's model.
Relays are common problem to '07 and early '08 like mine.
After replacing mine, never happened again for the following 5 years.
Hello everyone.
regarding this detail of the relays fans, a very fast and avoid buying possible solution is to remove and gently light shocks with a screwdriver ... and ready goodbye problem!
if symptoms persist ... repeat dose or renovate parts.
Greetings.
