have stock bushings but will be replacing with the Whitelines and new balljoints this winter for the front suspension and redoing all of the hardware and lateral arms for the rears. Need to make good use of my new garage this winter for some maintenance and playing with the P5.
I used this with my Honda Civic.
Thanks.
pickle fork. works everytime. since the arm is junk you dont need to worry about messing up the boot. just hammer the b**** in and it will pop 100% for sure. pickle forks are cheap.
Nice and way to rub it in. I'll either be in the driveway or in the garage but with the door open since I have to have 1/2 the car outside to leave room to work. One day I'll convert the breezeway to my 2nd bay!
, what is best way to remove the ball joint section from the steering knuckle?Sorry, first time ever replacing ball joints and there is no mention of this in the manual, simply remove bolt 2 in illustration and then move on to the four in the bracket.
well it took me years of wrenching in the snow/cold/borrowing garages before i finally have one of my own so i think I'm due. Plus one of the reasons i liked the house was the garage and piece and quiet. Looks like you need to clean the garage up, so you can have room indoors.
After you remove the pinch bolt you can hammer a chisel into the slot of steering knuckle right at the ball joint stud. That opens it up enough for the ball joint stud to just fall out.
It worked great for me.
Nice job!
You just have to hammer it out and then press the new one in?
alright few pictures of 626 balljoints in our OE LCAs.
abused and worn out OE balljoint
pressed out OE ball joint
new 626 balljoint installed
Sweet... Great pics! I'm excited now![]()
I have some questions regarding the ball joint and bushing replacement for the LCA:
1. To press out the old ball joint and press in the new ball joint, did you use a special tool? If so, what is it?
2. To press out the old bushings and press in the new bushing, did you need a special tool? If so, what is it? Does it slide out and in with pressure, no specialty tools needed?
The removal of the LCAs seems pretty straightforward, I don't know if this is a DIY job or if I need to take the LCAs to a machine shop with a hydraulic press. Thanks.
