My 03.5 Protege5 mostly sits in my garage. It has 58,500 miles on it. About a month ago, I was driving home from some errands and at a stop light it had a very rough idle and at times felt like it was going to stall (but doesn't). When the light changes and I give it gas, it feels fine. At the next light, it goes back to it's erratic idle. I topped off the gas, put in fuel injector cleaner and reset the PCM. After it sat for a few days, I drove it around the neighborhood and it seemed fine. Another week or so goes by and I drove it again to a restaurant. It was driving and idling fine until I was about halfway there, then at the next stoplight the erratic idle was back. It never stalled, but felt like it was going to. I made it to the restaurant and ate, when I left to come home I started the car and it had the rough idle right from the start. It was that way for most of my trip home, however, when I hit a few red lights towards the end of my trip home it was back to idling normal. It has always driven fine (even when the rough idle is there), it never seems to buck or do anything odd when I'm giving it some gas.
Last year, boostdprotegelx (Damian) worked on it to remove the vtcs after I sucked in one of the screws. It has run fine since that work was done on it up until this crazy idle started a month ago. Spark plugs were also changed last year.
Please help with suggestions. Might it be the EGR valve? or if that went bad would it not be intermittent and always idle rough?
