The Ohio Random Thread... aka We Should Probably Be Working
Do you have speed bleeders? If so, reapply hi-temp thread sealant to the threads to ensure that you aren't sucking any air into the lines.
I had some issues this spring when I let all of the fluid drain out of the lines, it just took a lot of time and bleeding to get all of the air out of the lines. Make absolutely certain that you got all of the air out of the MC. A mityvac or similar can help force fluid through the hard lines.
No speed bleeders - just the stock fittings. I use a Motive pressure bleeder and I've brought the pressure at the resevoir anywhere from 5-25 psi. Because of the positive pressure there shouldn't be any way for air to get sucked back into the lines. The Motive bleeder usually works great and allows me to bleed all four corners by myself in under 30 minutes. I went from a generic fluid ti ATE super blue so I knew when the lines were flushed so I'm not sure how air is still in there. I didn't check after the first but after the second MC bleed I could move the piston <1/16" usually all my strength with the ports capped. With the MC back on the car and the ports capped I was still getting good resistance. Only when I reinstalled the lines does the pedal get squishy.
You might have another bad master cylinder.
This is what I'm afraid of as there's always horror stories of new, aftermarket MC's being bad. I would think that since the MC is holding pressure once bled this isn't the case though.
I've got a bunch more theories (see my build thread).
While we're on the brakes topic, ive always bled my brakes the old fashion way. Should i continue this when i do the btakes on the ms3, or is there a better way? Never messed around with speed bleeders or anything before
its just sad that you want to get rid of it
99% my fault but I just feel even with taking it back to stock it's still going to be somewhat unreliable for a DD. Plus I've decided to stick with the Camaro as my only project car.
Old fashioned way works well. If you have a helper, no need to spend the money on equipment if you don't have to.
Try the old fashioned bleed method once or twice.
I'm going to try once more with the Motive bleeder. I'm going to get the car off jack stands and only raise the corner being bled, bring the reservoir pressure to 15 psi, let it sit for a few minutes (to check for leaks), and then very slowly bleed that corner until the reservoir is half empty. I'll do that for all four corners and if the pedal is still mushy I'll get my wife to help and do it the old fashion way.
I never messed with speed bleeders. I like the Motive pressure bleeder. Think of a pressurized lawn sprayer but instead of the sprary attachment it has a tube that connects to a cap that replaces the one on your MC reservoir. You fill the tank with brake fluid (or you cna leave it empty - just watch the reservoir!) and then pump it to add pressure. The pressure forces the new fluid into the MC and pressurizes the system. Then bleed each corner as usual. Before all this crap I could fill the tank, bring the pressure up to 15 psi, and bleed all four corners by myself in under 30 minutes. If you're creative you can probably make one of these things yourself but they're only like $30.
I'm looking into getting a power bleeder. I rarely have a helper so the ability to do it by myself would be awesome.
I need to do a full flush of the brake fluids and get some new fluid in there. I know the ATE Super Blue can be purchased in 2 colors so you know when the old fluid is completely flushed. Does anyone know if Wilwood EXP 600 brake fluid has the same? I'm not sure how I could tell when the old fluid is completely flushed without it being a different color. Anyone know of a trick to easily tell this?
I also need to install my Corksport SS lines first. Last time Evan and I tried to install them, we almost stripped the flare nut because it wasn't coming loose. I think some people have suggested using a torch to heat it up a little bit. If that doesn't work, they say use vise grips and pray LOL
Like I said in your build thread, Jon, double check the clutch line if it's connected to the MC as well.
#2, I thought of you when doing my brake lines a couple weekends ago, the first one started to strip. Son of a! I just put some Visegrips on it and all is well. Soak the fittings with some PB Blaster for the rest of the week before trying them this weekend.
I know of no other fluid that comes in a different color.
I just got my new brake lines yesterday. I will have the ate thursday so I hope everything goes to plan when I change everything all out
Haha I may try the visegrip/pb blaster method
Maybe the old fluid would look almost dirty or off-colored compared to the new fluid.
I believe there is a slight difference in color but it gets pretty hard to tell for sure. I use ATE. :)
hey guys i put up a thread for my stuff for sale from the protege. let me know if you are interested. ill give you guys a discount in here and bring it to mid ohio if you want anything
The new Wilwood 600 is almost clear. The old fluid will look more yellowish. Get some clear tubing and you'll see the difference when the old fluid is being flushed and the new fluid is coming through.
Will, does the ATE change color over time, like a darker blue or anything?
I went with the Wilwood 600 since it's available locally at Summit on the shelf if I get another seized caliper and have to swap them out and re-bleed that line.
Sorry, missed your post in my thread. The clutch MC is a completely separate unit so no luck there.
I've always used the "box" end of a wrench to do brakes. It may not be possible on other cars but on the RX-7 I slip the wrench over the fitting, then slide my brake bleeding tube over the port.
