Fiji Mazda3
- 2014 Ford Focus ST
The cost of the tow might be equal to trade in.
Tow it behind the Escape.
Since you're taking cars that don't work, how about a MSP?
No speed bleeders - just the stock fittings. I use a Motive pressure bleeder and I've brought the pressure at the resevoir anywhere from 5-25 psi. Because of the positive pressure there shouldn't be any way for air to get sucked back into the lines. The Motive bleeder usually works great and allows me to bleed all four corners by myself in under 30 minutes. I went from a generic fluid ti ATE super blue so I knew when the lines were flushed so I'm not sure how air is still in there. I didn't check after the first but after the second MC bleed I could move the piston <1/16" usually all my strength with the ports capped. With the MC back on the car and the ports capped I was still getting good resistance. Only when I reinstalled the lines does the pedal get squishy.Do you have speed bleeders? If so, reapply hi-temp thread sealant to the threads to ensure that you aren't sucking any air into the lines.
I had some issues this spring when I let all of the fluid drain out of the lines, it just took a lot of time and bleeding to get all of the air out of the lines. Make absolutely certain that you got all of the air out of the MC. A mityvac or similar can help force fluid through the hard lines.
This is what I'm afraid of as there's always horror stories of new, aftermarket MC's being bad. I would think that since the MC is holding pressure once bled this isn't the case though.You might have another bad master cylinder.
I can see that going very badly.Tow it behind the Escape.![]()
haven't been able to work on it?
Nope, too busy with moving and house stuff. Probably not until after Mid-Ohio.
its just sad that you want to get rid of it
While we're on the brakes topic, ive always bled my brakes the old fashion way. Should i continue this when i do the btakes on the ms3, or is there a better way? Never messed around with speed bleeders or anything before
I'm going to try once more with the Motive bleeder. I'm going to get the car off jack stands and only raise the corner being bled, bring the reservoir pressure to 15 psi, let it sit for a few minutes (to check for leaks), and then very slowly bleed that corner until the reservoir is half empty. I'll do that for all four corners and if the pedal is still mushy I'll get my wife to help and do it the old fashion way.Try the old fashioned bleed method once or twice.
I never messed with speed bleeders. I like the Motive pressure bleeder. Think of a pressurized lawn sprayer but instead of the sprary attachment it has a tube that connects to a cap that replaces the one on your MC reservoir. You fill the tank with brake fluid (or you cna leave it empty - just watch the reservoir!) and then pump it to add pressure. The pressure forces the new fluid into the MC and pressurizes the system. Then bleed each corner as usual. Before all this crap I could fill the tank, bring the pressure up to 15 psi, and bleed all four corners by myself in under 30 minutes. If you're creative you can probably make one of these things yourself but they're only like $30.While we're on the brakes topic, ive always bled my brakes the old fashion way. Should i continue this when i do the btakes on the ms3, or is there a better way? Never messed around with speed bleeders or anything before
Like I said in your build thread, Jon, double check the clutch line if it's connected to the MC as well.
#2, I thought of you when doing my brake lines a couple weekends ago, the first one started to strip. Son of a! I just put some Visegrips on it and all is well. Soak the fittings with some PB Blaster for the rest of the week before trying them this weekend.
I know of no other fluid that comes in a different color.
Sorry, missed your post in my thread. The clutch MC is a completely separate unit so no luck there.Like I said in your build thread, Jon, double check the clutch line if it's connected to the MC as well.
