- '13 CWP MS3 & '16 Mazda6 GT
that stoptech kit from them will be $140...just get the technas...
just purchase the techna fit kit from CR3.... $80 shipped.
Yeah. Take brake parts cleaner and spray around the injectors and see if it changes the idle and/or kills the engine.
Ok, good to hear. I'll remember these when I redo the suspension. Guessing you just have to take them somewhere to have the old bushing pressed out and new ones in?
I took starting fluid the other day and yes it did, I know I have a bad seal, I was just wondering if that was the cause for the lean code and the rough idling
it is highly possible. The smallest vac leak can cause issues
Looks like I'm gonna have to go look into getting some new seals then, thanks for the help!
So get 626 seals instead?
yeah, they're better
Ordered mine from rockauto.com for a few bucks. regular grooved seal on the left without the ribbed ring around it and the 626 seal on the right. More solid and fits very snug around the injector tip
[/IMG]![]()
What year 626?
when I ordered mine, I was actually just trying to get the o ring for top of the injector that goes into the fuel rail. But they come as a package with the o ring and both types of lower seals. You don't really have to look up the 626. I got mine by ordering for our cars. Honestly, I don't think the year matters for the 626, you should end up in the right place if you search by engine since they are the same engine.
Yeah I got the kits from rockauto for dirt cheap. Why are yours white? weird lol
lol, they are black. There was a powdery coating on it inside the package. I don't know why. I just wipe it off
Ok I found the injector seal set, Does just one seal come in it? Or does it have all 4? I can't find anywhere on there if it says just one or not
