2.0t03speed
- 08.5 CWP Speed 3
change the XXXXXXX to www. crossover auto . com
ooooooooooooooooooooooooooooooo you said a bad word next thing i know you will start saying street unit lol
I put 220 miles on the car since Saturday night and I've got an MIL because my rear O2 is dead. I knew it was going to happen because when the O2 bung was being welded onto my 3" exhaust, the sensor got cooked and removing it from the exhaust disturbed it. But I've got 2 extras, so no big deal.
Thinking of doing the wire tuck on my own on the msp.....
thats what i'm going to do after i get the msp inspected. supposedly it's pretty easy you just cut back harness and theres enough wire to tuck everything without extending wires.
Anybody ever used the Pedders control arm and trailing arm bushings that Crossover auto offers? Would these tighten up the suspension?
http://***********************/cros...=product_info&cPath=5_12_148&products_id=1213
http://***********************/cros...=product_info&cPath=5_12_148&products_id=1214
Very well could be, but not necessarily. Any leak after the MAF will cause a lean code.
I have the fronts and I noticed a difference. Took care of what little squishiness slop was left in the front. If you're doing the controls arms I would recomend them. I have gt spec trailing arms so I didn't use the rear set.
Yeah. Take brake parts cleaner and spray around the injectors and see if it changes the idle and/or kills the engine.Well it sounds like there's a vacuum leak coming from one of my injectors so I figured that might be what it is, oh and when my car idles the rpm's drop and pick back up over and over, could this be from a bad injector seal to?
What? I did no cutting on the harness
Has anyone purchased anything from AutoAnything? They've got a really good price on the StopTech SS brake lines...
