2nd Msp Build
Looks good mang, what made you not relocate your mad as you made your own pipe.
When I had my blue msp noticed the car was more inconsistent one day ran good someday okay when I had the maf relocated.... I believe from the radical temp change on the maf going from hot to cold that the output of the Maf changed because of the temp and as far as I know electronic sensor are affect by the temp like the msp coil packs and changes the output under load the intercooler cools more air which dirastically changes the temperature of the maf when relocated if it was left on the intake the heat range stays consistent threw out the whole time.... Second benefit is having less couplers or place that would have air leaks or turbulance basically less t-bolt clamps as I know get expensive when they begin to brake and why not recycle the cold air from my cold pipe instead of wasting it
Did you see that thepope is doing a sale thread on his downpipes?
I saw but at the same time the materials it would take me to make my downpipe is gonna be about 90 to 100 I'm thinking either make a divorced downpipe with a 2.75 pipe and 1in to 1.5in wastegate kind of like ion performance that will flare into a 3in... I have some sketches of what I want soon
you could inquire in just buying the casting. thats what i did and had a shop build the rest of it for me. I ended upwith a 3in dp with a 3inch catless midpipe installed for less then what he wanted for a completed down pipe at the time.
Finally getting the body and paint done
Getting some parts sandblast and paint also altered
Have to adjust the drop mainly in the rear
Plans are to get dynos before and after with the current mods which are precision fmic core with 2.5 inch one piece cold and hot pipe 2.5 inch exhaust from the s pipe back nology wires and walbro fuel pump also injen intake
i want that manifold
how much to do if i send you my manifold?
i have pretty much the same set up except my pipes are about 2.25, no nology wires and 3" turbo back exhaust wihtout cats.
can't wait for results, i have a MSP manifold laying around waiting for this mod.
I just bought a welding machine so a 3in turboback with a divorced dp Well be built after the dyno
