I have a 2003 Protege5 with about 106xxx miles, the car drives and shifts through all the gears just fine, but when I get to about 71 MPH the AT light starts flashing, (i can go over this speed and have, but weather I speed up, slow down, or stay the same speed, the result is the same) after about 30 seconds to 1 min of flashing the car shifts to neutral,(obviously I let off the gas to avoid over revving) then right back into gear (the correct one depending on my speed). I have heard this might be a speed sensor issue but I'm not sure. What could it be and what do I need to do??? Help?!? If you have more questions I might be able to answer them.
Thanks!!!!
Thanks!!!!
