Mp5t
Status
Not open for further replies.
I better warn the folks at Texas Mile about Brian. I don't think they're expecting a wagon to come by and blow the doors off their Lambos and Ferraris.
I somehow came across a video named MP5T and I knew it wasn't your current youtube, thought it may be an older one. Lots of videos on weapons, how to loosh absinthe, videos of your car. Very creepy
I'll keep an eye out on the account. If it resurfaces, I''ll report it and contact you. Onto another topic, nice shroud for the pusher swap, you can finally have that clearance :)
It's gonna work awesome...
and more updates..
The old ignition system you had, with the intel stickers...were the stickers just for show, or are you that awesome?
I thought it was funny.. I sold that ignition to a friend.
I definitely got a kick out of it. I figured they were just on there, but knowing you Brian, you most likely funded a new department at Intel computers for the research and development for ignition packs lol
Are those coils somehow sealed against the valve cover? I shampoo my engine about once every three days and would not want to have water pool down into the head past those coils.
If yours aren't sealed, is there some way to go about it? Does AEM have any kind of "boot" solution?
Because they share a common shroud, they need to come on exactly at the same time and at the same speed
If they come on any other way the air would just piss out the other.
Information for the 65mm BBK Mustang Throttle Body Modification.
The TB takes the Mustang TPS
TPS Part Number
#DY-967 F4SZ-9B989-AA
and
Wire Kit Part Number
WPT-993 1U2Z-14S411-AFB
They require an aftermarket EMS such as a Haltech or AEM.
So the Wastegate is Liquid Cooled.
The wastegate is fed by an AN4 Steel Line, but it goes near the Manifold and Downpipe.
The Lines are being protected by a Silicon Heat Sleeve. It is good for 1700 Deg F
Same thing on all of the lines including the Oil Feed to the turbo..
Relax guy
This is only test fitting.
Everything is getting hammered with Lye and made silver
Status
