How do you reduce boost? Running 7psi on a Disco Potato and I need to reduce the psi to around 3-4 before I blow something up. I've already been advised to get the right equipment for a tune but I need a stop gap in between. My understanding is that a MBC wide open will only keep you running stock or +1psi due to the restriction in the line. Anything that will reduce the pressure and let me start low and increase slowly?
Thanks
Thanks
