Will it clear AWR oil pan (height wise) ?
Sub
wondering this too... as well as a confirmation on the lower tie which was asked about earlier
The rear brace should be fine, you would have to sandwich the skid tray between the subframe and the brace. The front arm bar is most likely a no go but we have not had a car in with the bar in so we are not 100% either way.
-Derrick
to do an oil change you'd have to remove it ?
What type of aluminum is it , worrying about if it might corrode after a long winter or two ?
Whats the actual weight of it ?
Hey Derrick, I left you a message @ work. Call me![]()
