Spicey MSP Build underway!!!
Just Got the bolts for the dpipe, the 170 degree thermostat BUT the new dpipe flange gasket is backordered till the 16th. What do people think about reuseing the old flange gasket so I don't have to wait another week to finish
Looks good man! keep us updated on the 170 thermostat... i have the 160 stant fail safe in my car ang right now it takes forever to warm up and causes a check engine light.
I got mine from my local mazda dealer (if we are talking the turbo to dp gasket) it was like $27 but I got it that day.
Just got the engine this morning
Check out the bent rod
the 626 mani all cleaned up transferring everything over
Everything I've read in the service manual says the PCM only will throw a code if the engine coolant temp never reaches 160 F. i have a 170 so i should be good. i run a 160F in the mustang and its fine. The reason for a cooler thermostat is to reduce detonation cause by a hotter combustion chamber, to make conditions safer for boost. At least thats my experience with mustang tuning.
It's actually the factory head I just had it cleaned, resurfaced and port matched I wish it was a speed circuit tho ;)
lol nice.. how much did they charge u for p&p ur ports cuz i need to that to my speed circuit head :) befor i put the motor togther.. but i want to know how much it mite cost me?
These aren't mustangs though
DTC P0126
• If ECT signal never exceeds 71C {160F} after engine start for specified period, PCM determines that the
coolant thermostat is stuck open.
This is directly out of the Mazda Protege Service Manual. Page 01–02B–50. And obviously the MSP isn't a Mustang, I was just saying that its a boosted ECU controlled gasoline engine that runs fine with a 160F thermostat. Since the MSP thermostat is a 170F it should be fine.
