Nate I forget but do you have poly motor mounts?
70 front and back 88 on the sides (or whatever the middle duro is)
That's why you're hearing your engine. All the noise and vibration that was dampened by the stock mounts translates directly to the chassis which comes to you. The exhaust was drowning it all out before.
1,000 posts! don't think I've gone this far before...
After the first 1000, it gets easier...
Phen, I joined before you and I have way less. Some of us are just not as verbose as others.
I got a long way togo
hey Mike, I've been meaning to ask you what you think about the V-MAXX coils you got. Might not have much time to drive the car though but any comments are appreciated
Learn car first!
Learn car first!
Bearing in mind that I installed them the same time as my butterfly brace, I noticed a change in the car's behavior compared to the Bilstein PSS. Wheel movement is better controlled, there is less body roll and the car just feels more composed. Of course the spring rates being higher than the Bilstein's is a big help, but the damping seems to be well matched to the spring rates. The butterfly with the way it stiffens the car allows the suspension to track road imperfections without having to deal with flex. I'm used to it all now, but it was quite the eye-opener the first time I drove it after the install.
On another note, I've been cogitating (sometimes I talk like that) on it quite a bit, and I am going to try removing the rear sway bar and setting the front one on the softer setting when I get home. Although it's looking like I won't make the last points autocross, I am going to try to make the final fun run and see if that helps my oversteer problem.
OK, what sway bars do you have? and any idea how the MSM braces compare with the butterfly brace? I don't think they'll be as stiff but it might be close?
what I've read tells me the car should have a neutral balance with the coils given the spring rate ratio (3:2)
