I can't do it Friday but are you going to the Mid-Ohio Grand-Am race?
Found a puddle of fluid on the garage floor over the weekend under the left rear of the Speed3. Looks like the culprit is a bad shock:
Anyone have some advice/options for replacing this? I know Chippy had this problem a while ago and went with the BC coilovers. So those are definitely on the list, my other options are:
Mazdaspeed Coilovers (KW Variant 3), from Mazda Motorsports I can get them for $1525.07
Koni Yellows + what spring?
The Miata folks over at M.net say good things about Bilstein HDs but, at least for the Miata, they have to be revalved for the springs.
The less fun option is to just get the bad shock replace with a stock one.
Anything else I should be considering? How long should I be running around on the bad shock?
spring rates are 163 lbs/in(front) and 241 lbs/in (rear) or 3k front, 4k rear and thats the same spring rates for both the 3 and speed3 so you could save yourself about 60-70 bucks and just get the springs from the 3 instead of the speed3 springs
ill be out in akron, ohio next friday night if you want to meet up and go for a ride so you can feel how the stech/yellow combo is id be willing to meet up
You are? Or do you mean the 29th?
If you're not gonna track it go for the Konis, if it's going to see little track then BC's are fine but if it's going to see a lot of it, then I'd go with MazdaSpeed or H&R. If you're just looking for an excuse to upgrade stuff then go with the BCs, after you add springs to the Konis you'll be very close but Konis will be more comfortable DD depending where you live. I live in Parma and sometimes I don't like such a rough ride
lulz
I forgot to mention, you're welcome to ride in my car and see what you'd be dealing with. I know it would have helped me make up my mind
well considering this coming friday is the 22nd, next friday would be the 29th (hand) haha
dude even if you are going to track occasionally id still go konis and springs over the bc's... its only if i were tracking several times a year or autocrossing regularly that i would buy coilovers
and hey if you dont like the rough ride maybe we can work out a trade and you can have my koni's and stechs lol
Evan #2, I have Koni Yellows, H&R springs, and fatcat bumpstops... You're more than welcome to ride along and see how they feel.
So Levi, you are going to be in Ohio this weekend?
How much of a difference do the fatcats make?
no ill be around the burgh this weekend... its my bday this friday (22nd) so im keeping the weekend open to whatever the hell i want to do lol
That sounds good to me. What setup are you running?
I will probably take the MS3 to the track at some point, but it might be once or twice total. It's hard not to just take the Miata.
