Yes, that will cure the hesitation issue and will fix an a/f ratio but my problem is with the bogging. I have a hard time believing that such bogging is a result of a rich mixture. I think my a/f ratio may add to the problem, but is not entirely responsible. My issue is intermittent and is intense (to the point of requiring a tow truck because it is stalling and won't accelerate), not just annoying. Mazda can't figure it out because there is no CEL. Can a bad MAF or even bad plugs cause bogging this bad? I know bad plugs can cause a misfire and such but this is almost as if the car is on a limiter when the throttle is pressed too fast or any further than an 1/8th pressed.
